10-24-2016 06:44 PM
47 12
tools
  1. Viscomi4444's Avatar
    I don't like the 7edge. It's too curved. Ran hot. Screen too sensitive. I had it for 12 days while waiting on replacement. Not for me.
    Then 2nd issues... Note5... Like it
    I found that the screen sensitivity reduced drastically after a couple weeks use for the note7 (original and replacement). I'm sure the s7 edge would be the same. Too bad it didn't work out for you.
    10-22-2016 12:53 AM
  2. Joeykool's Avatar
    I saw there is a way to side load the theme. Is that what you did?
    I got the theme. Are you rooted or did you figure a way to get package Disabler to work. Theme resets after a short period since the update. Thanks
    10-22-2016 01:18 AM
  3. sweetypie31's Avatar
    It's ok, little Schlubbe, your note 7 is just going to go live on a farm where it can run and play all day.
    Love how two different comments in the thread say 'it isn't lesser' and then include the word 'minus' in the next sentence. A $50 isn't lesser than a $100 - it's the same thing, minus a ten and a couple twenties.
    Obviously, I ordered it, and I'll be doing the swap - whole point of the thread is just that I really don't wanna (like the rest of you, I'd guess).
    Well I stand by what I said. Honestly none of us wanted to give up our N7. I was just pointing out that s7 edge is an acceptable phone even though it doesn't have every function that the N7 has. They are almost the same phone. It's suitable replacement. At least in my opinion. Anyway good luck with whatever phone you choose.
    amyf27 likes this.
    10-22-2016 05:55 AM
  4. wolverinex's Avatar
    Not rooted,use package disabler .apply theme,then kill these programs👍👍
    Attached Thumbnails Replacement S7 Edge arrived... I don't wanna do the switch!-340.jpg
    10-22-2016 09:03 AM
  5. Joeykool's Avatar
    Ahh....I missed the second one... Thanks
    Darn.... It reset even with those killed. I think the n7 got an update that disables this from what I read?
    10-22-2016 11:01 AM
  6. nobrakes's Avatar
    You have to clear data when you click on those items. Not just check the boxes
    10-22-2016 05:43 PM
  7. Schlubbe's Avatar
    So, I just fired up the S7 edge - it's got the N7s sim card and has the 256gb card in it. Still have a dozen more things to get dialed in, but it seems pretty nice so far. It has this week to win me over, but I'm pretty sure I can get used to it.
    Still, not going to push the old N7 out on an ice floe just yet(senicide? more like sevenicide).
    I was thinking I could store it on the warming rack of my dormant bbq grill until the vzw box turns up, just to avoid further chiding from the bedwetter brigade. Whaddya think?
    (My God! That's right next to the propane tank! He's going to kill us all! Won't you at least think of the children?)
    If it goes, I guess I'll see you in Heck!
    boudicca and From A Buick 8 like this.
    10-22-2016 05:54 PM
  8. Joeykool's Avatar
    Thank you... I'll try that
    10-22-2016 07:00 PM
  9. Nostromo79's Avatar
    I just can't used to the curved screen. My palm always hits it and causes issues. Was gonna get a s7e but opted for the v20 instead. If I could get the injustice Batman s7e..... I would go for that for sure!
    Yes, Injustice looks pretty slick. Personally, I believe the Olympic version (can't believe it's been two months already) seems a gem too with its presentation case.
    10-23-2016 10:38 AM
  10. Joeykool's Avatar
    Yes, i saw a video on it! I think there is an iron man galaxy too. Might he older version?
    10-23-2016 10:55 AM
  11. Jaycemiskel's Avatar
    I have a replacement edge here as well. While I don't think my Note 7 is going to blow up. Who knows when I'll get a return box. I would feel safer having it with me than just having it at my house unsupervised while I'm at work during the day.
    10-23-2016 11:03 AM
  12. Nostromo79's Avatar
    This is the first I'd heard of the possibility of any sort of Iron Man version (there ought to be though!); could be an earlier device yet I've only recently become aware of these high-line, limited editions. I am going to check Amazon and eBay*.
    *eBay has the Iron Man S6 Edge; used only that I found. A nice looking phone.
    10-23-2016 12:06 PM
  13. ibaad86's Avatar
    I am unable to make VOIP on my samsung s6 using Viber or Skype. I can sometimes hear the other Party (like on facebook-messenger) but the other party can't hear a thing. On other apps like whatsapp, it's not even connecting! Other than that, I can make Normal calls over cellular network, even voice messages are working properly too.
    I tried everything factory Reset Install and reinstall Viber etc, but yet Nothing seems to work. If someone knows the the answer to my problem, please help me!!!
    10-23-2016 12:46 PM
  14. dlgus's Avatar
    My Co-Worker received her replacement N7 then the return box for the old N7 came a week later. She then received an email that confirmed they received her first N7 back! She is like what do I do with the extra phone, every one at work said together "keep it". lol
    She's probably not going to be able to use it much longer...why keep it?
    10-24-2016 10:32 AM
  15. From A Buick 8's Avatar
    I am starting to doubt they will disable it.
    Still have mine and it is going strong.
    athenatp and Adaboy like this.
    10-24-2016 10:45 AM
  16. fragologist's Avatar
    Look forward to the Note 8.
    From A Buick 8 likes this.
    10-24-2016 11:29 AM
  17. Bcool's Avatar
    The edge really isn't a lesser device. It's the exact same phone minus a few functions and the s pen.
    Minus=Lesser. You said it yourself.
    10-24-2016 11:30 AM
  18. Bcool's Avatar
    And please, does there always have to be a 'chicken little' in every thread pointing out that this evil little phone will burn down my house, knock Aircraft out of the sky, stage a coup d'etat in a 3rd world country, and kill my puppy, Duane?
    I get it, it might possibly catch fire. You can stop now.
    The pictures I've seen doesn't even look like it really catches on fire, just melts. Certainly doesn't explode like all the stories say. A cardboard box to ship it back? no protection against "explosion". This whole thing has been exaggerated and "blown" out of proportion. I'm keeping mine until they brick it. Everything else is lesser. Everything....
    amyf27 and From A Buick 8 like this.
    10-24-2016 11:43 AM
  19. ThrottleJohnny's Avatar
    Can we stop this? Is there really a need to continually take swipes at an excellent device that's like, 7 months old? It's really off putting.
    10-24-2016 12:10 PM
  20. billinaz's Avatar
    Not even close. The form factor is completely different. I really like the N7 form factor, I have a S7E now and I absolutely hate it.
    10-24-2016 03:51 PM
  21. Adaboy's Avatar
    I agree I don't hate it, but when it was released I went in to upgrade and just didn't pull the trigger. The curved edges are way more pronounced than the N7. It wasn't bad I just wanted to wait.. Each passing day I just can't give up my N7.. I know everyone will say it's your life etc...
    10-24-2016 06:02 PM
  22. sweetypie31's Avatar
    Minus a few functions that the N7 does not have and will get. That doesn't mean that the phone is inferior to the n7
    That's your opinion as my statement was my opinion. I have no problem with the form factor of either phone. I initially thought I would have that issue with the S7 edge, but I don't.
    Yall can stop quoting me because I won't change my opinion no matter how many don't agree. At the end of the day I really don't care what device anyone besides myself sticks with. I offered my opinion to the OP. Lol
    10-24-2016 06:44 PM
47 12
  1. How do I turn off Hey Siri?
    By r56mcs in forum Samsung Galaxy S6
    Last Post: 11-06-2016, 01:28 PM
  2. Blue Coral Samsung Galaxy S7 edge officially launches in November
    By Tiko7523 in forum Samsung Galaxy S7 edge
    Last Post: 10-27-2016, 12:13 AM
  3. Replies: 2
    Last Post: 10-22-2016, 04:16 AM
  4. So I installed the Pixel launcher...
    By lrrowley in forum LG V20
    Last Post: 10-21-2016, 06:40 PM
  5. What's next in the Phablet world?
    By kyle0k in forum Samsung Galaxy Note 7
    Last Post: 10-21-2016, 04:20 PM
