    My phone is Galaxy note Fan Edition
    04-01-2019 10:35 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! First things first -- you're certain the Ringtone volume slider is turned up, right?
    If you go to the Settings>Sounds menu and select a new ringtone, does it play a sample for you? Are you using a preinstalled ringtone, or a custom one?
    04-02-2019 12:16 PM
  1. OK Google tells me I "must unlock my phone to do that"
    Last Post: 06-20-2019, 11:02 PM
  2. Blu vivoxl4 can't answer phone, does not show screen
    Last Post: 04-02-2019, 02:18 PM
  3. Replies: 2
    Last Post: 04-02-2019, 12:45 PM
  4. Calendar entries made on phone don't sync to PC
    Last Post: 04-01-2019, 07:20 PM
  5. Replies: 1
    Last Post: 04-01-2019, 06:15 PM
