1. BBLou's Avatar
    Does the Note 8.0 have some special USB charging circuit? I was looking to get an external battery pack for charging on the go and was told that units like the Ravpower 10400 mAh battery pack would not work with the Note 8.0 due to Note's "unique design of the charging port? Anyone know?
    Thanks,
    L.S.
    09-09-2013 11:01 AM
  2. srkmagnus's Avatar
    Thanks,
    L.S.
    One end of the port may be unique to the Note 8, but the other end is USB, correct? That's the end you'll be plugging into the external battery pack, which will (and should) work without a problem.
    09-09-2013 08:27 PM
  3. BBLou's Avatar
    Actually the Note end is a micro USB and the other is a standard USB. I was told actually by the battery pack seller that there is something unique about the Galaxy tabs but I'm not finding any real data that says there is. This is a quote from the Amazon.com listing for the Ravpower 10400 battery pack:
    "Charges one device at maximum speed or two at 3A total. One 5V / 3A (max) port charges Android devices and Apple devices with iOS 5 or higher at full speed; One 5V / 3A (max) port charges ALL Apple products at full speed (also charges Android devices at 0.5A).Note: this product CANNOT charge Samsung or Asus tablets."
    09-09-2013 08:39 PM
  4. Manikandan Ramakrishnan's Avatar
    I think they are referring to the old Samsung tablets that have a propriety charge port. It shouldn't be a problem with the Note 8.
    Sent from my GT-N5110 using Tapatalk 4
    09-18-2013 11:42 PM
  5. gemniii's Avatar
    I've used several generic micro usb chargers, they all work. Back in the day, with a previous PDA, I found some mini-USB's had one less wire and wouldn't work to charge.
    09-19-2013 02:51 PM
  6. pressurecooker's Avatar
    I had Asus tablet and it has charger with usb port but actually charges at 12 volt. Got to be careful not to plug anything else into Charger!
    09-25-2013 11:21 AM
  7. Haalcyon's Avatar
    I've charged my LTE Note 8.0 with several battery packs and all kinds of chargers and car chargers. No problems whatsoever.
    S IV
    09-29-2013 09:02 AM
  8. Coach0209's Avatar
    Yes it has a charge plug like the galaxy s8 it isn't the micro anymore it's a lil wider and you can insert it either way so there is no upside down or anything.
    08-24-2017 11:03 PM
  9. OniKyanAE86's Avatar
    It's a USB C plug now...
    08-29-2017 08:23 PM
  10. B. Diddy's Avatar
    A reminder that this thread is about the Galaxy Note 8.0 tablet, not the upcoming Galaxy Note8 phone. The tablet had a microUSB-A port, while the phone will have USB-C.
    08-29-2017 08:27 PM
  1. Replies: 13
    Last Post: 12-21-2013, 11:20 AM
  2. Replies: 74
    Last Post: 09-26-2013, 07:19 PM
  3. Replies: 3
    Last Post: 09-11-2013, 12:52 PM
