1. ZarathustraHead's Avatar
    I ran out of internal space on my 16gb Note 8, so I bought an SD card. After putting the SD card in, I was still getting messages that I was out of space. The tablet was not putting new stuff in the memory card. It was still using internal memory. So I had had to delete from the internal memory to make more space. What good is the memory card if the Note 8 doesn't use it? Is there a way to get the Note 8 to use the memory card?
    sent from my Note 3
    10-19-2013 11:51 AM
  2. Haalcyon's Avatar
    Applications aren't going to run from the SD card w/out some rooting/hacking (if then). You can store pictures, videos, and music on the memory card though.
    10-19-2013 12:45 PM
  3. ZarathustraHead's Avatar
    Pictures. Videos. Music. All the stuff I run from my phone instead of my tablet. Oops. Guess I'll buy 32gb next time.
    Thanks for your response.
    sent from my Note 3
    10-19-2013 12:55 PM
  4. bclinger#IM's Avatar
    Another routine action: routinely clear the cache:
    Via my Note 3
    10-19-2013 12:55 PM
  5. ZarathustraHead's Avatar
    Via my Note 3
    What is cloudagent? Is that cache? It was taking 3gb so. I deleted it but have no idea what the effect will be.
    sent from my Note 3
    10-19-2013 02:03 PM
  6. bclinger#IM's Avatar
    10-20-2013 04:24 AM
  7. gemniii's Avatar
    sent from my Note 3
    With an upgrade to 4.2.2 many apps CAN be moved to the SD card. However many people had problems with the upgrade.
    10-21-2013 07:49 PM
  1. Odds of Blocking Mode in 4.3 Update
    By Wildo6882 in forum Verizon Samsung Galaxy S4
    Last Post: 10-29-2013, 12:07 AM
  2. Using the G2 at the gym
    By shadowsjc in forum LG G2
    Last Post: 10-23-2013, 02:20 PM
  3. Sprint Galaxy S3 - is the esn also located on the mother board
    By arcolino in forum Sprint Galaxy S III
    Last Post: 10-21-2013, 09:02 AM
  4. Note 2 > Note 3
    By ZarathustraHead in forum Samsung Galaxy Note 3
    Last Post: 10-20-2013, 09:03 PM
  5. "Look After your Stone", the most absurd app [GAME?]
    By RamdomApps Developer in forum Android Apps
    Last Post: 10-19-2013, 11:05 PM
