jrsharp70 Well-known member Aug 24, 2012 841 0 0 Visit site Jun 6, 2014 #1 Anyone else getting bad WiFi signal, s note problems, and battery drain? I keep having to restart.
M mobilecrackers Well-known member Jul 16, 2013 500 0 0 Visit site Jun 7, 2014 #2 jrsharp70 said: Anyone else getting bad WiFi signal, s note problems, and battery drain? I keep having to restart. Click to expand... This is most common in kit kat. Go to recovery and clear cache and data/factory reset .. clearing data will remove all the downloaded apps. if you don't want to clear the data then clear the cache
