Save big + get 3 months free! Sign up for ExpressVPN today
  1. Brahmanda Gede's Avatar
    My screen usage has been like this for two weeks.
    I'm already uninstalled most app and removing my photo an video in my device, and nothing changed.
    Usually my screen battery usage was under 40 percent.
    Did anyone know to fix this?
    Sorry for my bad english.
    Attached Thumbnails High battery usage on Galaxy Note 8.0-screenshot_2015-03-16-16-31-18.jpg
    03-16-2015 04:36 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The percentage isn't as important as the total time the screen has been on. Remember that the percentage is relative--so that if you're doing less of other activities on the device, then the screen will be responsible for more of the overall battery usage. What is your total screen-on time?
    03-17-2015 03:53 PM
  3. MAXXTX's Avatar
    Open up the back and disconnect the battery for an hour. You can open up the back with either a plastic pry tool or I use my finger nails. If you need to see how to disconnect the battery wire heres a video. DONT UNSCREW IT lol just saying. you can skip to 4:47 to where they disconnect it.
    03-21-2015 06:10 PM
  1. When will Android L roll out to Finland on Sony Xperia Z2?
    By AC Question in forum Sony Xperia Z2
    Last Post: 03-29-2015, 03:03 PM
  2. Galaxy s5 charging cables no longer work
    By nodakskip1 in forum Samsung Galaxy S5
    Last Post: 03-23-2015, 04:42 PM
  3. galaxy s3
    By Dsnuts81 in forum Ask a Question
    Last Post: 03-16-2015, 05:16 AM
  4. Rooting not allowed on Android One
    By Aeneas06 in forum Legacy Android & Other OS's
    Last Post: 03-16-2015, 02:38 AM
  5. Drawing on the tablet + lag?
    Last Post: 03-16-2015, 01:47 AM
