Hi,
I removed the battery from my Galaxy Note 8 and noticed that the tablet still shows information that the battery is charging when plugged to the charger. If it's not plugged the tablet won't start because it shows the battery on 0%.
I removed the battery because the tablet is not charging. When i plug it on the charger it keeps showing the battery image as charging but it never passes 0%. I tryied another battery and the problem kept the same. I tryied to charge with other chargers but nothing helped.
I find strange that the tablet shows the battery charging even when it has no battery connected to it.
Hope you can hell me.
Thank you.
06-01-2015 01:30 PM
