1. AC Question's Avatar
    The home button doesn't respond when pushed either. Not great using tablets....mostly been a pc windows 7 user.
    06-16-2015 11:06 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Since the Home button is a physical button (as opposed to the capacitative Back button), I would guess that there's a hardware issue with that row of buttons. Does this persist after a reboot?
    06-17-2015 02:13 AM
  3. Bushpilots's Avatar
    Tnx B Diddy....confirms what I suspected.....I looked on all kinds of help sites and nobody seemed to have my exact problem....a reboot doesn't help...it's off warranty and not sure what a fix would cost so will likely suffer with it the way it is.
    06-17-2015 02:05 PM
  4. B. Diddy's Avatar
    One other thing to try is booting into Safe Mode, to see if the problem is being caused by some app you installed. I can't find specific instructions for the Note 8.0, but try the steps for the Note II: Safe mode, galaxy note II, n7100, gt-n7100,GT-N7100TADXSG
    06-17-2015 11:18 PM
  1. Jump the ship or Wait for Note 5?
    By sup3r1or in forum Samsung Galaxy S6 edge
    Last Post: 06-20-2015, 08:37 PM
  2. Replies: 1
    Last Post: 06-19-2015, 10:55 AM
  3. Replies: 2
    Last Post: 06-17-2015, 12:49 PM
  4. Note 4 to Nexus 6
    By faith3935 in forum Google Nexus 6
    Last Post: 06-17-2015, 08:35 AM
  5. Can a Chromebook upload a file while in sleep mode or when logged off?
    By londonsleepapnea in forum Acer Chromebooks
    Last Post: 06-17-2015, 02:26 AM
