1. Amna Akhtar's Avatar
    My note was working great until 3 days back.When i try to charge my battery ,it simply doesnt charge,i tried cleaning the ports ,draining it out completely (removing the battery to remove whatever charge was there on the mother board),factory reset everything i could find on the internet.
    suddenly it started charging on its own, but again it does not charge,battery retains charge and there is no over drain or anything .
    The device seems to charge when ever it wants.
    I am not sure what the problem is ..hardware ,software ..i am so confused...
    has someone had this problem before...
    08-11-2015 11:30 AM
  2. BlackDragon22's Avatar
    Have you tried using a different charging cable? Sometimes the micro USB cable becomes bent over time and then won't charge the phone properly.
    I had the same problem with my iPhone 5 last year and it ended up being the cable. I swapped it out for another cable and it charged normally.
    08-11-2015 12:58 PM
  3. Amna Akhtar's Avatar
    nope that didnt work ,going to dump the note :-(
    08-13-2015 11:16 PM
  1. I hate waking up to Note 4 poor battery life
    By ericmazariegos in forum Samsung Galaxy Note 4
    Last Post: 08-20-2015, 04:33 PM
  2. Password Protect apk and Play Store installation?
    By IFeelYourPain in forum Android Apps
    Last Post: 08-11-2015, 12:39 PM
  3. Replies: 1
    Last Post: 08-11-2015, 11:54 AM
  4. Replies: 0
    Last Post: 08-11-2015, 10:58 AM
  5. Replies: 0
    Last Post: 08-11-2015, 10:00 AM
