Using a memory card in the Note 8
ZarathustraHead
325
I ran out of internal space on my 16gb Note 8, so I bought an SD card. After putting the SD card in, I was still getting messages that I was out of space. The tablet was not putting new stuff in the memory card. It was still using internal memory. So I had had to delete from the internal memory to make more space. What good is the memory card if the Note 8 doesn't use it? Is there a way to get the Note 8 to use the memory card?
sent from my Note 3
Haalcyon
Banned
Jul 19, 2013
7,662
Applications aren't going to run from the SD card w/out some rooting/hacking (if then). You can store pictures, videos, and music on the memory card though.
ZarathustraHead
325
Pictures. Videos. Music. All the stuff I run from my phone instead of my tablet. Oops. Guess I'll buy 32gb next time.
Thanks for your response.
sent from my Note 3
gemniii
Active member
Aug 2, 2013
33
sent from my Note 3
With an upgrade to 4.2.2 many apps CAN be moved to the SD card. However many people had problems with the upgrade.
phone user
