lisarahder
Which version of KitKat is causing these problems? It is August 2015 now, has there been a KitKat patch that solves it?
Hi I have the problem with my Samsung Note 8, its been like it for over a year. Im not very Android savvy, would you be kind enough to direct me through what you did to fix yours? Thank you
See response to your other post: http://forums.androidcentral.com/sa...y-life-over-heating-problems.html#post5115253
Those instructions are pretty useless for this issue. It can really only be fixed by changing to a different version of android (as i did with cyanogen mod to fix the overheating) wiping the cache and disconnecting the battery for a decent amount
of time to reset what the system sees for the battery (somehow gets a memory and only uses a small percentage of the battery life? No amount of tuning or battery monitoring will get around this).
