j_hansen
with the Neo Hybrid can you use just the soft flexible inner without the bumper?
I'll know on Monday anyway but just curious
I guess you could but as Baby-Doc said, it would be slippery-er and much less protective. Why would you not want to use the bumper? It's very unobtrusive.with the Neo Hybrid can you use just the soft flexible inner without the bumper?
Can you provide a link? That isn't a Note 8 in the photo either...You can get one of these Sandstone finish thin cases from eBay or the Bear Motion or Imak Cowboy case which is similar.
//uploads.tapatalk-cdn.com/20171121/f411a06ae35f3588242f231efd831a60.jpg
It does not provide any drop protection but gives a very minimalistic grippy feeling.
Yeah doesn't look like the Note 8 but here's a seller on eBay.Can you provide a link? That isn't a Note 8 in the photo either...
