1. lazyhound's Avatar
    Any suggestions for a car mount that can handle the depth of the UAG Monarch case as well as the weight? In the past I have used the vent magnet mounts but the phones were smaller. I would consider getting a thinner case if it had decent protection and mrsnt better mount choices.
    12-29-2017 05:20 PM
  2. amyf27's Avatar
    This is what I use the dash Mount I would need to reinforce with velcro so for now I have it on the windshield and it doesn't move at all I use that case with my phone I even use it with the defender and have never had problem.UAG Monarch and Car Mount-smartselectimage_2017-12-29-18-32-16.jpg
    12-29-2017 06:33 PM
  3. sleepnclass's Avatar
    Iotties mounts work.
    02-14-2018 02:29 AM
  4. amyf27's Avatar
    This works with mine well. I'm also going to try a popsocket mount to see how that works.
    02-14-2018 08:58 PM
  5. fireidiot's Avatar
    Best mount I have ever used was from Proclip. www.proclipusa.com
    03-05-2018 02:03 AM
  1. Replies: 3
    Last Post: 01-04-2018, 06:29 PM
  2. Youtube and soundcloud and that sort of apps keep pausing randomly
    Last Post: 01-01-2018, 01:26 PM
  3. Videos on my phone are playing in slow motion - both streaming and saved ones.
    Last Post: 12-29-2017, 07:14 PM
  4. My Droid Turbo 2 is dead and won’t turn on
    Last Post: 12-29-2017, 06:57 PM
  5. Replies: 2
    Last Post: 12-29-2017, 04:21 PM
