1. manhattan123's Avatar
    Has anyone experienced this? The volume controls on my Note 8 reset just about every day to zero.
    Ringtone, Media, Notifications, System...all change to silent, and I have to manually bring them back up. It seems to hold for a while at my preferred level, only to have it happen again later.
    What causes this? Is there a way to prevent it?
    Thanks.
    07-07-2020 04:49 PM
  2. B. Diddy's Avatar
    Is Do Not Disturb scheduled to turn on at a specific time?
    07-07-2020 05:02 PM
  3. mustang7757's Avatar
    I agree check DND, if that's not the issue safe mode to see if any 3rd party apps causing the problem
    07-07-2020 07:01 PM
  4. manhattan123's Avatar
    Thanks for the response folks. Do not disturb was not on, in fact I had to search for it, I didn't even know where it was, but it hadn't been inadvertently turned on.
    I haven't added any new apps in about 3 months, and this just started happening last week, so I don't know if it could be one of them, but I'll check to see if it's an app.
    It's very frustrating when a somewhat major control on the phone just changes for no apparent reason.
    07-08-2020 10:38 AM
  5. mustang7757's Avatar
    Quickest way is safe mode to determine if a 3rd party app causing this .
    B. Diddy likes this.
    07-08-2020 11:26 AM
  6. B. Diddy's Avatar
    I agree with mustang7757, here are the steps: https://www.t-mobile.com/support/dev...g-galaxy-note8
    07-08-2020 08:49 PM
  1. One+8 Waterfall display compared to Note 9+ or 10+? Any input?
    By Yguideslou in forum OnePlus 8 & OnePlus 8 Pro
    Last Post: 08-18-2020, 03:11 PM
  2. Note 10+ Battery issue, moisture related after being in rain.
    By SKalber in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 07-21-2020, 04:42 PM
  3. How to turn off in-call volume on S10+?
    By Justin502 in forum Samsung Galaxy S10 & S10+
    Last Post: 07-08-2020, 08:45 PM
  4. How to turn off in-call volume?
    By Justin502 in forum Ask a Question
    Last Post: 07-07-2020, 03:40 PM
  5. Replies: 2
    Last Post: 07-07-2020, 03:04 PM
