Originally Posted by
B. Diddy I think I've seen this issue discussed before, but it always puzzles me how an Android device wouldn't give the user an option to select the USB connection protocol from the notification panel.
Do you even see the USB notification when you connect? If so, what do you see when you tap it?
i see people say that, but i don't see it on my device. might that's carrier specific, which wouldn't make sense. if i go into develop options then i can see usb connection then select mtp.
there are the only options i see on my drop down notification panel
![phone/pc not syncing together [Solved - Post #67]-not2.jpg](https://forums.androidcentral.com/attachments/samsung-galaxy-note-8/328194d1603596836t-phone-pc-not-syncing-together-solved-post-67-not2.jpg)
