I've tried forgetting the headphones a few times but this has not resolved the issue. Last night I discovered that if I changed the Media Volume settings on the phone (Samsung Note8), sometimes I can get the audio to play through the headset. However, just a slight adjustment and I will loose the audio. Following is an image of the adjustment on the phone.
In the above image, what is the white area on the Media setting? This is the setting that either restores or loses the audio in the headset. Sometimes just a slight adjustment will either loose the audio or restore it. Why do I loose the audio with a slight adjustment?
