According to BGR, the Note 8 for TMO will not be compatible for LTE band 71, TMO's new 600MHz network T-Mobile customers: Don’t buy a Galaxy Note 8 – BGR
The 600MHz frequency shouldn't matter to most people anyway unless you're in a rural area.
Even the iPhone 8 won't have this...who cares.
That article says it might not.
I'm betting on the iPhone 8 ...maybe. Hopefully. Idk LMAO
does anyone know if the unlocked version of the Note 8 not specific for T-Mobile would work on the 600MHz network?
It will support it. A T-Mobile rep said the S8 and note 8 series will get a firmware update for official support of that band. Also, if you do your research you will find out that the snapdragon 835 has the snapdragon X16 LTE modem which supports the 600 mhz band.
