1. D13H4RD2L1V3's Avatar
    Well, here are the specs for the secondary camera.
    It's a 1/3.6" sensor with a 12MP effective resolution, resulting in a pixel size of approximately 1-micron, coupled with an optically stabilized f/2.4 lens and a roughly 52mm-equivalent focal length, resulting in a 45 degree field of view.
    Long story short, while the presence of OIS will be a big deal for stability and can help aid in soaking up a bit more light due to slower shutter speeds, this isn't a camera you'd want to use in low light.
    Even though it is very possible to drop the shutter speed down to as low as 1/15s or 1/10s, the camera module itself won't be as good at soaking up light compared to the main camera. There is kind of a reason why it's called a secondary camera.
    With all that being said, the sensor is just part of the package. It remains to be seen just how the software is able to compensate, though David on Android Police reports that the Note 8 seems to resort to using the primary camera when shooting photos in very challenging light conditions.
    Aquila, skatergirl and Serkle K like this.
    08-24-2017 07:22 PM
  2. Aquila's Avatar
    Thanks for the work up front on the research and analysis!
    08-24-2017 08:13 PM
  3. dpham00's Avatar
    Hopefully Samsung will provide seamless integration like Apple. It will automatically choose the best between primary Digital zoom and using the telephoto lens.
    skatergirl likes this.
    08-24-2017 08:20 PM
  4. chyeo1979's Avatar
    Think all camera (phone or dedicated) will use optical zoom first before digital zoom. So the first 2x will be optical and further zoom will be digital. Dun think there is an option to use digital zoom for the first 2x.
    08-24-2017 08:27 PM
  5. dsignori's Avatar
    Thanks for the info! Sounds like the camera will automatically switch away from the secondary camera in low light situations ... https://www.androidcentral.com/samsu...note-8-cameras
    08-24-2017 08:42 PM
  6. dpham00's Avatar
    In even moderate indoor situations, the iPhone will default to the digital zoom over the telephoto lens "optical zoom". That is even at 2x.
    I have pics of digital vs optical zoom here on the iPhone if interested.
    https://forums.imore.com/iphone-7-pl...ml#post2854285
    08-24-2017 08:50 PM
  7. palmor's Avatar
    It isn't a 2x optical difference though because the "equivalent" focal length is a combination of sensor size and lens focal length. With a smaller sensor the lens focal length is not 2x the main camera although the equivalent focal length is.
    Still better then cropping the main camera in good light I'm sure but there is a bit of marketing speak in there.
    08-25-2017 08:11 AM
  1. Replies: 293
    Last Post: 09-17-2017, 07:09 AM
  2. Replies: 3
    Last Post: 08-28-2017, 04:15 PM
  3. stuck in upgrade mode
    By Perry Lee in forum Ask a Question
    Last Post: 08-24-2017, 07:25 PM
  4. Replies: 0
    Last Post: 08-24-2017, 06:49 PM
  5. Issue with samsung galaxy s7 edge when using selfie stick
    Last Post: 08-24-2017, 06:18 PM
