I have Verizon, and I've never had a phone with an FM tuner. Must be carrier specific.
Verizon shuts it off on all of their phones.
Less filling.....Worked when I had my s8+ on Verizon
How, I have s8 plus and I don't see it anywhere. I've been blind before.. LolWorked when I had my s8+ on Verizon
I've never had it enabled, by Verizon, on any Android phone.
Just install any fm app. You will know on next radio because it instructs you to plug in headphones if it has an fm radio instead of just letting you pick a station if you are streaming from the webHow, I have s8 plus and I don't see it anywhere. I've been blind before.. Lol
Do you mean a Verizon demo device?It works, I'm using it now on my Verizon Note 8 with Next Radio.
From what I've heard before, if you have wifi AND a cell connection, apps use the wifi for radio. To truly tell if your using FM, turn off wifi. If it works, the FM chip is activated. Is that correct?
