09-07-2017 07:06 PM
26 12
tools
  1. svtcobra's Avatar
    Does anyone know if the FM chips will function or is it all still carrier related?
    09-02-2017 03:43 PM
  2. njdan30's Avatar
    Works on mine but I'm sprint I have enabled on other non sprint devices before though but idk about the note 8 don't see why it would be any different though
    09-02-2017 06:53 PM
  3. jadedangel143's Avatar
    Oh, how you get this to work?
    09-04-2017 02:34 PM
  4. mountainman's Avatar
    I have Verizon, and I've never had a phone with an FM tuner. Must be carrier specific.
    boudicca00 likes this.
    09-04-2017 04:41 PM
  5. Ryano89's Avatar
    Verizon shuts it off on all of their phones.
    09-04-2017 05:01 PM
  6. cliberti's Avatar
    Worked when I had my s8+ on Verizon
    09-04-2017 06:01 PM
  7. mountainman's Avatar
    Less filling.....
    Tastes Great!
    I hope it has it.
    Serkle K likes this.
    09-04-2017 06:12 PM
  8. trucksmoveamerica#AC's Avatar
    How, I have s8 plus and I don't see it anywhere. I've been blind before.. Lol
    09-04-2017 07:52 PM
  9. svtcobra's Avatar
    I've never had it enabled, by Verizon, on any Android phone.
    09-04-2017 07:56 PM
  10. Ryano89's Avatar
    I've been with Verizon for almost a decade, and they have disabled it in every phone I've ever had.
    09-04-2017 08:11 PM
  11. maf113's Avatar
    you need two things to get fm radio. an app like Next Radio and wired headphones or earbuds. The radio uses the wires in the headphones as the antenna and the app accesses the fm tunner.
    Works great on my Verizon S8
    Serkle K, sparkeater79 and AdamHLG like this.
    09-04-2017 08:27 PM
  12. cliberti's Avatar
    Just install any fm app. You will know on next radio because it instructs you to plug in headphones if it has an fm radio instead of just letting you pick a station if you are streaming from the web
    09-04-2017 09:24 PM
  13. sparkeater79's Avatar
    It's works on my Verizon s8 as well. Next radio app and wired headphones
    09-04-2017 09:28 PM
  14. anon(10305333)'s Avatar
    It works, I'm using it now on my Verizon Note 8 with Next Radio.
    09-06-2017 04:04 AM
  15. rushmore's Avatar
    Works on the Verizon 8+, even after the recent update over the past several months.
    09-06-2017 03:48 PM
  16. rushmore's Avatar
    Do you mean a Verizon demo device?
    09-06-2017 03:52 PM
  17. anon(10305333)'s Avatar
    No demo, my Note 8 got delivered yesterday.
    09-06-2017 04:41 PM
  18. svtcobra's Avatar
    From what I've heard before, if you have wifi AND a cell connection, apps use the wifi for radio. To truly tell if your using FM, turn off wifi. If it works, the FM chip is activated. Is that correct?
    09-06-2017 05:27 PM
  19. anon(10305333)'s Avatar
    I just tried it with airplane mode on and it didn't work. I tried it with just wifi off and it does work. It uses the cell connection for data to display station info, but it does work without wifi on.
    09-06-2017 05:37 PM
  20. kuhawksr1's Avatar
    Thanks for this info!! I was worried. Among other uses I prefer walking into football games with just my phone and corded headphones so I can listen to the local broadcast team without the delay or hassle of streaming. Very much appreciate knowing this works on Note 8. I've used it with NextRadio on my Verizon S7E and now look forward to the same with my Note 8.
    anon(10305333) and highstar like this.
    09-06-2017 07:33 PM
  21. anon(10305333)'s Avatar
    You're welcome and that does sound like a great way to use the FM tuner.
    09-06-2017 08:03 PM
  22. recDNA's Avatar
    My Verizon OG Droid had it. My Thunderbolt may have but that was the last.
    09-06-2017 08:22 PM
  23. Fr0gburp3r's Avatar
    Is the FM Tuner on the unlocked version?
    09-06-2017 09:54 PM
  24. rushmore's Avatar
    Cool Is the signal wimpy like the Note 7 was? The Note 4, S7 and 8 Plus all are significantly better with signal than the Note 7 was.
    09-06-2017 09:55 PM
  25. anon(10305333)'s Avatar
    I didn't get the Note 7, but the signal is good it picks up all the main stations and I'm in a rural area.
    09-06-2017 10:41 PM
26 12
  1. Anyone getting a watch to go with their Note 8
    By Stealthieone in forum Samsung Galaxy Note 8
    Last Post: 05-09-2018, 07:55 PM
  2. Will One Plus 5 work with Cricket wireless?
    By PachecoCorporationCeo in forum OnePlus 5 & 5T
    Last Post: 01-05-2018, 03:43 PM
  3. Could someone tell me how to flash T-Mobile rom on AT&T Note 3?
    By heading4tomorrow in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 09-03-2017, 12:48 PM
  4. nook will not recognize my eyes
    By poett15 in forum Ask a Question
    Last Post: 09-02-2017, 10:38 PM
