09-15-2017 10:10 AM
47 12
tools
  1. androidonly91's Avatar
    I was one of the lucky ones to be able to get my note 8 already. I received it yesterday, today is the first real test of using it on a daily basis, Had the phone on the charger until I left the house Around 10:30 this morning and it is now only 5:41 p.m. and my battery life is all the way down to 36%. Does anyone have any tips or tricks on how to get the battery life to last longer, I already have everything turned down not running 4k or having the screen brightness all the way up... I think I might be sending this back faster than it came, even though I got it 10 days early lol
    09-07-2017 05:44 PM
  2. Preach2k's Avatar
    It takes a little bit of time for the battery to fully cycle thru charge cycles, and once you get a new phone there's gonna be software updates so that's gonna prolong the battery life , the stuff inside the battery need time to expand and contract, kinda like breaking in brand new headphones , at first the new headphones sound good but you thought they sounded better but after about 100hours of play time with them they start to come in think that's the same thing with a new battery
    103Softail likes this.
    09-07-2017 06:47 PM
  3. androidonly91's Avatar
    I sure hope so man, a lot of money to spend on a phone I just switched from my s8 + and that battery blows me away with how long a charge last! I'm just glad I have tmobile because I have "jod" so i can get a new phone every week if i really wanted.
    09-07-2017 07:48 PM
  4. Ca_lvn's Avatar
    Give it a few days it will get better
    09-07-2017 08:01 PM
  5. Ca_lvn's Avatar
    Plus most likely on a new phone you have more on screen time than you realize
    09-07-2017 08:01 PM
  6. kj11's Avatar
    It's virtually impossible to recommend anything with the information you provided. Have you looked at what's using the battery? That would be a good place to start.
    Got over 5 hours of screen time yesterday, on Pace for the same today on high performance mode
    kevinpleasants likes this.
    09-07-2017 09:36 PM
  7. Amele's Avatar
    My battery life has been meh for the two days I've had it set up, and it lost a lot overnight, but it has gotten heavier use these two days than it probably will usually. I just went through and put a bunch of apps to sleep, and turned off auto sync on some, and maybe that will help.
    09-07-2017 09:57 PM
  8. androidonly91's Avatar
    Yea I know that I went through every setting for apps and put them all to sleep, then in also turned down the screen res, what else is there to close or change ?
    09-08-2017 02:08 PM
  9. androidonly91's Avatar
    Yea I know that I went through every setting for apps and put them all to sleep, i have also turned down the screen res, what else is there to close or change ? I also keep the brightness down
    09-08-2017 02:11 PM
  10. kj11's Avatar
    What kind of screen on time are you getting?
    Settings>device maintenance>battery
    09-08-2017 02:17 PM
  11. solotristan88's Avatar
    how do u tell on screen time? doesn't say
    09-08-2017 07:57 PM
  12. kj11's Avatar
    Then click on battery usage at the top under the estimated time left
    09-08-2017 08:24 PM
  13. androidonly91's Avatar
    Here's a pic for you
    09-08-2017 08:26 PM
  14. androidonly91's Avatar
    09-08-2017 08:31 PM
  15. solotristan88's Avatar
    then do u click on screen?
    09-08-2017 10:30 PM
  16. solotristan88's Avatar
    I am getting 4 hours 50 min with 19% left.
    09-08-2017 10:33 PM
  17. kj11's Avatar
    You guys will both get over 5 hours of screen on time, which is really good. Are you not happy with that?
    09-08-2017 10:42 PM
  18. solotristan88's Avatar
    I am...it's just a less than the S8plus...which would last forever...but smaller phone/screen with larger battery...I get it.
    09-08-2017 11:59 PM
  19. androidonly91's Avatar
    I am content with it just a little less battery life then my s8+ and that phones smaller
    09-09-2017 12:21 AM
  20. kj11's Avatar
    Gotcha. I guess I was confused because yesterday you were sending it back faster than it came
    09-09-2017 12:42 AM
  21. kj11's Avatar
    Meanwhile... No complaints here...
    Zolti likes this.
    09-09-2017 12:50 AM
  22. androidonly91's Avatar
    Are you on it 24/7 I'm always on it using it for work or face book ECT...
    09-09-2017 05:49 PM
  23. kj11's Avatar
    I assume that's why the screen on time matters.... Yesterday the phone was off the charger for 18 hours, 6 and a half with the screen on
    stuckingoo likes this.
    09-09-2017 06:48 PM
  24. Stealthieone's Avatar
    I think 6.5 hrs is about the average screen on time.. which is pretty great
    09-09-2017 07:03 PM
  25. rushmore's Avatar
    Agreed, but still will not stop overstated claims of miracle level battery life. SOT with heavy use, ten hours! Heavy use being browsing
    09-09-2017 08:33 PM
47 12
  1. Gear s3 won't turn on after battery was drained
    By norbs1127 in forum Samsung Gear S3
    Last Post: 09-14-2017, 11:23 AM
  2. fingerprint/iris not unlocking note 8
    By KnightRyderX in forum Samsung Galaxy Note 8
    Last Post: 09-08-2017, 08:27 AM
  3. Replies: 5
    Last Post: 09-08-2017, 04:50 AM
  4. Unlocked note 8 question
    By alejovh1#AC in forum Samsung Galaxy Note 8
    Last Post: 09-07-2017, 04:05 PM
