1. Sammuel1973's Avatar
    It works on all other screens, able to hide, and swipe up from the bottom for it to reappear. I can't find it under Settings.
    09-15-2017 02:54 PM
  2. anon(238680)'s Avatar
    From the manual:
    Displaying or hiding the navigation bar
    Using the Show and hide button at the left side of the navigation bar, you can set the
    navigation bar to be hidden or pinned on the screen when you use apps or features. The
    navigation bar is pinned by default.
    If you want to view files or use apps in full screen, double-tap the Show and hide button to
    hide the navigation bar.
    To show the navigation bar again, drag upwards from the bottom of the screen.
    On certain screens, such as the Home screen, the navigation bar will always be
    displayed and the Show and hide button will not appear.
    • Even after you pin the navigation bar, it can be hidden while using some apps or
    features, such as a video player.
    09-15-2017 02:59 PM
  3. Yuvalhad12's Avatar
    If you use nova launcher you could hide the status bar
    09-15-2017 03:09 PM
  4. Sammuel1973's Avatar
    Great. Where in settings?
    09-15-2017 04:15 PM
  5. toenail_flicker's Avatar
    Sammy lets us do it now.
    09-15-2017 04:26 PM
  6. Js2000ster's Avatar
    You can also double touch the dot on the bottom left corner of the screen to hide it.
    Edit: sorry I see u wanted to remove it from the home page. Lol
    tekjunkie28 likes this.
    09-15-2017 05:35 PM
  7. Yuvalhad12's Avatar
    Look and feel -> hide navbar (in the lowest section)
    lv2bsilly likes this.
    09-15-2017 06:39 PM
  8. lv2bsilly's Avatar
    Thank you! Seeing it on my homescreen was driving my OCD self crazy since the icons are above it lol.
    Sammuel1973 likes this.
    09-15-2017 10:22 PM
  9. Yuvalhad12's Avatar
    No problem
    09-16-2017 02:19 AM
  10. Sammuel1973's Avatar
    Same here.
    09-16-2017 02:32 AM
  11. Sammuel1973's Avatar
    No problem
    You are awesome, thanks.
    Yuvalhad12 likes this.
    09-16-2017 02:32 AM
  1. New to the forum
    By Kibaima in forum New to the Forums? Introduce Yourself Here!
    Last Post: 09-24-2017, 06:12 PM
  2. Replies: 6
    Last Post: 09-18-2017, 10:38 PM
  3. No Google Voice Search/Google Now on Samsung Keyboard?
    By Sammuel1973 in forum Samsung Galaxy Note 8
    Last Post: 09-18-2017, 04:16 PM
  4. Oreo on 6P -- FPS slow to open?
    By quelquehomme in forum Nexus 6P
    Last Post: 09-16-2017, 06:20 PM
  5. GALAXY S4 (not the Mini) Black Screen. Is it gone forever?
    By Caren4u2 in forum Samsung Galaxy S4
    Last Post: 09-15-2017, 03:58 PM
