11-14-2019 10:35 PM
113 ... 2345
tools
  1. Baby_Doc's Avatar
    I think it's unfair to say that all N8 owners have this battery problem. They don't. While there are several complaints about wireless charging problems, not everyone has that issue, either. Only Samsung knows how extensive these problems are.
    While it has to be a pita for anyone with a problem, that's what warranties are for. Don't expect a recall of everyone's phone unless they begin exploding again.
    Jewels81 likes this.
    12-28-2017 08:31 PM
  2. chanchan05's Avatar
    Even without this issue, you shouldn't be letting your battery die in the first place anyway. Just because you can doesn't mean you should.
    12-28-2017 09:01 PM
  3. mike104393's Avatar
    I read this is a known issue with Samsung and they are replacing phone on a case by case. Either way, glad to know you fixed your phone
    12-28-2017 10:59 PM
  4. ClintRo's Avatar
    This times ONE MILLION!!
    12-29-2017 07:22 AM
  5. datum9's Avatar
    Li-ion battery is full at 4.3V.
    Dead at 3.6V. It shuts down around 3.55V.
    Put a voltage meter app. It's the most useful thing there is battery-wise. It also measures temp. You don't want to hit 40C.
    for best battery heatlth:
    1. Don't go below 3.7V, start charging then
    2. Charge when the phone is off.
    3. Charge with low Amps, turn off fast charging.
    12-29-2017 09:04 AM
  6. JN81's Avatar
    This isn't just a Samsung problem, I think it is an Android problem because the same thing happened to my HTC 10 the week before Thanksgiving. Been using an S8+ ever since but I haven't let it go to 0% yet.
    12-29-2017 11:41 AM
  7. chanchan05's Avatar
    No it's neither. It's a known risk for all lithium ion batteries. Although the units for Samsungs may possibly have defects, all lithium ion batteries have a risk of discharging below critical level if you let it drain to zero. Some companies cough*Apple*cough manage this by telling you the phone has zero percent left but it actually has 5% left. There are also rumors that 100% on an iPhone is actually 95% capacity.
    Whatever the cause, fact remains that discharging to zero carries risks. I wouldn't even experience this issue at all if I had a Note 8 with battery problem like this.
    12-29-2017 01:04 PM
  8. notefreak's Avatar
    I have had mine run to zero and all was fine. Does that mean I am not affected?
    12-31-2017 11:11 AM
  9. jhimmel's Avatar
    It means you are not affected so far.
    12-31-2017 11:17 AM
  10. bhatech's Avatar
    While I agree, but sometimes you may be in certain circumstances where you are in locations out of reach of chargers etc when it completely runs out of charge. Or personally like me (odd case) who has multiple devices, when I switch between then sometimes I leave the phone unattended for days which case it would run out of charge. There are many other instances and not every case it's because someone purposefully let's the battery drain to 0%.
    Personally, I don't know if it's a real problem or not but I don't think solution is don't let it drain to 0% since that may happen sometimes for variety of reasons.
    12-31-2017 11:47 AM
  11. DarkSorrow's Avatar
    I haven't had issues with mine. It's died a few times and always powered back on when charging. I have 3 24500 mah power banks though around the house and car. Warning!! Do not let your battery die!-screenshot_20171231-155430.jpg
    12-31-2017 03:56 PM
  12. Tsepz_GP's Avatar
    This must be a Snapdragon Samsung problem . I have let my Exynos Note8 has die a few times and each time I just plug in to the charger and it charges no problem.
    01-01-2018 06:08 AM
  13. notefreak's Avatar
    I am also on Exynos and no problem.
    01-01-2018 06:18 AM
  14. dov1978's Avatar
    Surely Samsung should be forcing the phones to power off before absolute zero? I had a Huawei P10 before my N8 and when it got to 3% (I'm sure?) it notified you that you had 30 seconds to connect to a charger or it was shutting down which it normally did because I was fumbling around trying to find charger
    Lyndal Coote likes this.
    01-01-2018 06:49 AM
  15. frankenhooker's Avatar
    Same here, in fact there are two Exynos units in my house and neither, as yet, seem to have the problem.
    01-01-2018 11:49 AM
  16. pool_shark's Avatar
    I've seen so many threads about this issue, and I have been waiting to see someone besides myself with this thought.
    I charge my phone whenever I want, in the car, overnight, when I'm watching TV, etc.
    I am aware also that there are people who for whatever reason buys every new phone, so they have multiple devices, which makes me think of something else.
    Stats say that most people don't have $1000 saved, have no emergency or retirement fund, and have a mountain of credit card debt.
    I sincerely hope that those who have to have all of the latest toys take care of those financial needs first.
    01-01-2018 12:51 PM
  17. DarkSorrow's Avatar
    Mines Qualcomm I believe and have no issues if it does die. Warning!! Do not let your battery die!-screenshot_20180101-125643.jpg
    01-01-2018 12:57 PM
  18. Fred98TJ's Avatar
    01-01-2018 05:46 PM
  19. Sophie Fournier's Avatar
    Hi all,
    I just had this problem earlier today. I had never had an issue with charging my few month old Galaxy S8. Today I let it completely drain to 0%, it wasn't the first time though! I plugged it in and got a black screen with a lighning bolt in a circle. I tried a few different combinations of charging cords, wall adapters and outlets and got the same symbol a few times but the phone never seemed to charge. Then it stopped doing anything at all. I tried holding the power button down and holding the power and volume down buttons together. Nothing worked. Finally in a last ditch effort, I put my phone on my old "slow" charging wireless charger... nothing happened. I then plugged in my fast charger cord at the same time and held down the power and volume down button and low and behold the safe boot option screen came up! I have no idea why it worked, but it did.
    03-13-2018 02:53 PM
  20. j_hansen's Avatar
    using a USB port on a computer and leaving it overnight often does the kickstart as well
    msingh48 likes this.
    03-13-2018 05:04 PM
  21. srgonu's Avatar
    My Note 8 recently ran out of battery and shutdown completely. I didn't try to do anything other than charging and it came back rocking.
    bassplayrguy likes this.
    03-13-2018 06:27 PM
  22. Iva_LadyDiCaprio98's Avatar
    The times my phone went to 0% and shut off was never intentional. It's due to circumstances where my powerbanks have not been charged up and I have no way of charging my phone. However, my phone always turned back on once I did plug it in to charge. Never had the issue where it didn't
    03-13-2018 06:46 PM
  23. wkupharm1's Avatar
    My Note 8 died overnight this weekend, while taking updates. Sunday morning I woke up to a dead phone, that would not charge. My buddy works for a company, who happens to refurb some of the phones AT&T take back. He told me the most common way they fix this issue when they come around, is to connect a wireless charger and once they are paired, connect the regular fast charger at the same time. I did this, and in about 30 seconds my phone had the lightning bolt on the display, and about 5 minutes later it was at 10%. Note the wireless charger I have, is one I used with my S6 Edge that I bought off Amazon for like 15 bucks...its not a fast charger, but it did the job for me.
    w7sg likes this.
    07-02-2018 12:31 PM
  24. monkeycsk's Avatar
    i am very curious as to how you could possibly pair your 'dead phone' with the wireless charger???
    kixfan likes this.
    07-03-2018 09:00 PM
  25. kixfan's Avatar
    That was my first thought too.
    07-05-2018 02:22 PM
113 ... 2345
  1. Cannot use Chrome; strange warning message displays
    By LaurieDutch in forum Samsung Galaxy S7
    Last Post: 04-14-2018, 04:12 PM
  2. Does OK Google work on your phone with the screen off?
    By xandros9 in forum General News & Discussion
    Last Post: 09-24-2017, 04:23 AM
  3. Upgrade Samsung GT-P7510 - can not get above Android 4.0.4
    By Terry Weymouth in forum Samsung Galaxy Tab 10-inch
    Last Post: 09-21-2017, 12:12 PM
  4. How do we get into Recovery Mode on the Note 8?
    By jejb in forum Samsung Galaxy Note 8
    Last Post: 09-20-2017, 02:28 PM
  5. How do I turn off AP Fastboot Flash Mode?
    By Stu Smither Wulsin in forum Moto G
    Last Post: 09-19-2017, 07:09 PM
