1. The Photon Guy's Avatar
    After I got my Galaxy Note 8 on Tuesday Last week I realized that I was probably going to loose the stylus for the Note 8 at some point in my life (probably pretty soon). I realized I had a Note 7 stylus I saved from the Note 7. I tried to use it on the Note 8 and low and behold it works!! It also fits perfectly into the same slot that holds the stylus within the smartphone. When you hold both styluses right next to each other they look almost identical!!
    09-21-2017 05:59 PM
  2. wildcard30's Avatar
    From what I have seen online they are supposed to be identical.
    09-21-2017 06:15 PM
  1. Gifs wont Loop on Samsung Messages
    By Eddie Gamboa in forum Samsung Galaxy Note 8
    Last Post: 11-30-2017, 05:05 PM
  2. Hi anyone know how to fix the flash notifications on the S5?
    By Kxng_Alez in forum Samsung Galaxy S5
    Last Post: 09-28-2017, 09:31 AM
  3. Android 7 for Galaxy Note 4?
    By rbrown6061 in forum Android 7.0 Nougat
    Last Post: 09-23-2017, 04:59 PM
  4. Debris on edges of tempered glass screen protector
    By JoshDunc in forum Samsung Galaxy Note 8
    Last Post: 09-21-2017, 04:31 PM
  5. is there a mini hdmi cable that splits to power and info
    By Jon Johnson3 in forum General Help and How To
    Last Post: 09-21-2017, 03:47 PM
