I have a Sprint Note 8 and can't get the edge lighting to work? Anyone else having this issue? I have made all kinds of changes to the settings and nothing.
Help! Please.
Help! Please.
I find that it works if the screen is on and logged in, on my note8. I was hoping it would work if the aod was on.
Agreed 100%.Mine works but to be honest it is so watered down from the old edge lighting that I do not use it.
Make sure that in advanced settings for edge lighting that you have transparency set to low and that the width is wide. Now see if it works for you.
Ye, to me that was one of the top reasons for using the edge. I still would never go without the edge panel for apps again. It's great being able to just swipe my thumb once click and I'm in whichever of my apps I'm using most that week, or in a function widget like device maintenance.Agreed 100%.
For those who don't know, this used to be an amazing feature on the S7 Edge. You could set a color for each of your contacts. When you placed the phone upside down on a desk or other surface, when one of those contacts called or texted you, the display would light up whatever color that contact had so you knew who contacted you.
This feature on the Note 8 is completely different. It's also completely removed on the S7 Edge now.
I never got it to work on mine. Tried everything I can think of (settings, advance settings, notifications, etc). Nothing. I can preview it no problem, but getting it to work is another matter altogether.
Nope. Done all that. Even turned on Edge Lighting in the notification bar thinking that was the cause. But nope. It's still doesn't work for me.*My edge lighting is working perfectly....
Follow these steps;
(1) Click Settings, Click Display, Click Edge Screen, Click Edge lighting (mine is on Always). Click on the Word Always to enter sub menu.
(2) Click Manage notifications, Choose what you like, I have Messages, WhatsApp, Email, and Gmail selected. Back out one page.
(3) Click on Advanced Settings, Highlight Custom color Then click on the round DOT to the right of the word Custom color, Setup your cutom colors choose done, then back out a page and set Width all the way over to the right.
(4) Top right of page press Preview, when your happy with your color back out all the way Your Done!
*Notifications have to bee setup like this to work, there not album color. Do exactly what I wrote and you guys should be fine.
