Wondering if all notes are the same. Will an unlocked T-Mobile note 8 be able to have full function on the Verizon network?
Thanks
Thanks
I'll wait until the Verizon folks chime in, but while it would work, carrier-specific functions might not.
Vvm won't work either. Not sure if the tmobile version has all the radios enabled for verizon? You can always flash the Verizon software, if technically inclined.This. VoLTE/WiFi calling most likely won't work.
