1. leerandall's Avatar
    How do I turn on Find My Mobile on a Verizon Note 8?
    09-22-2017 10:27 AM
  2. smooth4lyfe's Avatar
    Search it in settings...hit the search button at the top right and type "Find My Mobile"
    09-22-2017 10:45 AM
  3. comestim's Avatar
    I think Google Device manger is allot easier to use than the Samsung one. I use it all the time with my wife's phone to see if it is safe to call her after work so I do not ring her when she is working.
    09-22-2017 10:56 AM
  4. leerandall's Avatar
    A search does not find it on a Verizon Note 8 because Verizon removed Samsung's Find My Mobile, as I just learned from a Verizon Support chat I just concluded. But I did find the Google Find My Device. On Verizon Note 8s, its under Settings -> Google -> Security -> Find My Device. It was turned on by default.
    anon(238680) likes this.
    09-22-2017 11:14 AM
  5. smooth4lyfe's Avatar
    Wow Verizon removes every nice Samsung feature geez
    09-22-2017 11:16 AM
  6. leerandall's Avatar
    I know, and I just don't understand why they do that.
    09-22-2017 11:19 AM
  7. anon(238680)'s Avatar
    Exactly the same as they did for the S8 series and exactly the same discussion. Use the online Android Device Manager site and you're good to go.
    09-22-2017 11:35 AM
  8. dpham00's Avatar
    Yeah it is unfortunately disabled on the Verizon version. You can flash the unlocked software to get features that Verizon removed, if you are technically inclined.
    09-22-2017 11:38 AM
  9. leerandall's Avatar
    You wouldn't happen to have a list of features that Verizon removed from their Note 8s specifically, would you? I only find out that something is missing when I look for it and it's not there.
    09-22-2017 12:01 PM
  1. Getting closer: Exclusive: T-Mobile, Sprint close to agreeing on deal terms.
    By VW Maverick in forum General Carrier Discussion
    Last Post: 11-07-2017, 07:57 AM
  2. will t mobile note 8 unlocked work on Verizon?
    By dbow27 in forum Samsung Galaxy Note 8
    Last Post: 09-22-2017, 11:44 AM
  3. Apps open that I didn't open....Samsung Galaxy 7...help!
    By headscratching80 in forum Ask a Question
    Last Post: 09-22-2017, 11:17 AM
  4. Replies: 2
    Last Post: 09-22-2017, 10:31 AM
  5. Replies: 0
    Last Post: 09-22-2017, 09:51 AM
