1. droidntn's Avatar
    Which is better done our battery conservation?
    09-22-2017 11:34 AM
  2. dpham00's Avatar
    Wifi
    09-22-2017 11:35 AM
  3. Almeuit's Avatar
    It truly depends on the strength of said signal. WiFi is usually better unless you have a good LTE connection. A good LTE connection is easy on the battery just like a good WiFi connection is.
    09-22-2017 11:35 AM
  4. chanchan05's Avatar
    As previously stated, the one with better signal.
    09-22-2017 11:53 AM
  1. Replies: 7
    Last Post: 09-22-2017, 08:34 PM
  2. Where is the Samsung Find My Mobile setting on a Verizon Note 8?
    By leerandall in forum Samsung Galaxy Note 8
    Last Post: 09-22-2017, 01:01 PM
  3. Replies: 3
    Last Post: 09-22-2017, 12:41 PM
  4. Replies: 1
    Last Post: 09-22-2017, 11:22 AM
