Mike328
4hrs OST with 15 hours is not excellent @ 8% battery life left. You should be getting at least 6 hours..
I never get 6 hours of screen on time
it's BK Package Disabler and it's awesome. helps trim the garbage so your phone runs fast and smooth.
https://play.google.com/store/apps/details?id=com.kunkunsoft.packagedisabler&hl=en
Awesome. I was looking through the apps list and found you can disable through the phone itself, is that not as good as the BK disabler
Well 6 hours is pretty easy. U must have slow signal or something running in the backgroundI never get 6 hours of screen on time
Two full days and it's just now about to go on the charger.
