- Nov 18, 2014
- 783
- 0
- 16
How often do you use the phone?
Coming from a Note 5, my Note 8 battery life is far superior. Actually makes me think my N5 had a failed battery from the beginning. It was my first android phone so I didn’t know any different but I rarely got over 2 hours SOT. Note 8 easily gets 4 and last well through the day for me.
No, I'm on Verizon. Idle drain was definitely the problem. I don't get the best signal at my house but even when I traveled to areas with excellent signal I had the same problem.That's interesting. I had a Note 5 in 2015 and returned it to TMo because of idle drain. Because it's now on Nougat, I just picked another one up on Swappa (in almost new condition). Last night I left it unplugged on my nightstand and it burned through 2.5% per hour. Went from 100% to 86% just doing normal syncing overnight. Yet the mAh usage in the battery screen indicates it only used about 200 mAh uot of 3000. Doesn't make a lot of sense. Were you on Tmo per chance?
Well, here’s mine
(The Facebook logo is for a wrapper btw, not the official app)
View attachment 270165 View attachment 270166
Manual brightness. I keep it around 40%. I also set it to Medium power saver just for the CPU limiter, as I don’t need full performance all the time and have it set to FHD+.Really impressive. Exynos processor right? They say in past phones they are much more efficient than SnapDragons... from what I read about an hour better.
What level do you have your screen brightness at? Are you at default display setting or full resolution?
Two full days and it's just now about to go on the charger.
Quite honestly, I’m chuffed as my battery performance with no power saving modes at all in QHD+ isn’t far off what’s here. 5.5 hours average is what I would get. Best I’ve gotten was nearly 6.
And yes, it’s an Exynos
First week i ran it in high performace mode with just bluetooth and location switced off and I averaged about 6 hours sot since then I switched to next level down and are seeing nearly 5 hours of sot with 50% battery left, it's a European unlocked non-carrier, exynos dual sim
my note 5 got to the point with me where the battery would just drain out . my wife's s7 had the same size battery an was much better. my n8 has been a beast
It never came with any bloat. I uninstalled the Samsung and Microsoft stuff that I didn’t need though. Disabled the pre-installed Facebook app too.Disabled any of the Bloatware if your carrier have any?
