1. boriqua2000's Avatar
    Here's a video of 2 issues i have with my note 8. I have no trash can to delete icons on my home screen and the photo gallery is all messed up when i scroll up and down.
    09-27-2017 03:54 AM
  2. Stealthieone's Avatar
    Press and hold the icon? Should give you options. Do a factory reset. If that doesn't work return it for a replacement
    Bosbouer likes this.
    09-27-2017 04:23 AM
  3. Carl051's Avatar
    Have u turned off animations. I had this issue with s8+ turning on animations allows u to delete icons again
    boriqua2000 likes this.
    09-27-2017 04:51 AM
  4. Bosbouer's Avatar
    On nougat press and hold any homepage icon and a sub menu will pop up giving tye various options amongst others to remove from the homescreen.
    09-27-2017 06:52 AM
  5. boriqua2000's Avatar
    You were right. I turn them back on and i was able to delete the icons. Thanks
    09-28-2017 03:54 AM
  1. Help- Default spen for handwritten text entry
    By CaroI G in forum Samsung Galaxy Note 8
    Last Post: 09-28-2017, 07:13 PM
  2. Fast charging speed on note 8
    By boriqua2000 in forum Samsung Galaxy Note 8
    Last Post: 09-27-2017, 02:55 PM
  3. Hi How can I connect webRTC app to my Peerjs server?
    By sadok90 in forum Ask a Question
    Last Post: 09-27-2017, 01:09 PM
  4. Samsung S5 Mini with Strange UI
    By S7MiniQuestion in forum Samsung Galaxy S5 Mini
    Last Post: 09-27-2017, 11:23 AM
  5. Replies: 1
    Last Post: 09-27-2017, 10:58 AM
