I couldn't find it. Just to turn off the sound when removing the s pen, not while writing.I would imagine under S Pen settings?
Thank you. I didn't see that last part.In settings mine says Sound: Play sounds when you insert or remove the S Pen or write on the screen. Then you can toggle it off. So it looks like you have to turn both off at the same time.
