chazglenn3
Trusted Member
I leave mine charging overnight every night, always have.
Same here.
charging overnight
I had a very similar experience with my Note 5. After the second or third night the charging circuit was toast. I couldn't charge it hardwired or wirelessly.
It's happened to me before and it was a photo editor doing it to mine check all your new appsI would recommend the app AccuBattery. It shows a wealth of information about your battery and what's using it. Also shows current battery capacity vs. designed capacity and gives the rationale for not charging to 100%, and not leaving on charge overnight.
I wasn't sure on this either so I use an aukey power brick which turns off after phone reaches 100% when I charge overnight. But coming from Note 5, I'm so impressed with N8 battery life.Is it safe for the battery to leave it on overnight? It won't harm the battery leaving it on the charger after it's full?
