1. Dan Salvetti1's Avatar
    So I have a Spigen Though Armor case right now. I love the way it looks, the way it feels in the hand, and the level of protection you get from it.
    The thing that drives me NUTS though, is that it's impossible to write on the screen with the S pen when the phone is flat on the table. The case has zero grip or rubber on the back, and I have to hold it with one hand while writing. When trying to just write with one hand and not actually hold it down, it constantly moves around.
    Any suggestions on a similar case that will grip to a table when I write and not move around? Also one that will sit flat on a table.
    Thanks!
    09-30-2017 09:13 AM
  2. srvctec's Avatar
    The grippiest case I've found is the Speck Presidio Grip. I love my cases grippy and the Spigen Rugged Armor Extra is what I started with. I added grip tape to it but because of the design, it still slides around on flat surfaces. I was in the local Sam's Club last weekend and saw they had the Speck for only $30 vs. $40+ online, so I got one. Absolutely love it for the fantastic grip in hand and on flat surfaces. My only complaint about it is that it's very difficult to remove from the phone. I'm almost afraid I'm going to break my phone getting the case off. But I'd rather have a grippy case than one that comes off easily.
    09-30-2017 09:27 AM
  3. Dan Salvetti1's Avatar
    Is it a flat-backed case also? The past Speck cases I had always had a bit of curvature on the back.
    09-30-2017 09:30 AM
  4. srvctec's Avatar
    It does have a very slight curve to it but it grips like crazy to whatever flat surface it's put on. For me, I can't imagine a better case, although I don't write on my phone while it's on a flat surface. Just tried that and it would be annoying because of the slight curvature of the back, rocking a tiny bit when writing.
    evohicks likes this.
    09-30-2017 09:35 AM
  5. Dan Salvetti1's Avatar
    Yeah, my issue is that I use it to write on for call notes almost daily
    09-30-2017 09:38 AM
  1. Popup Fullscreen Ads on my s8! Help please!!!
    By Candywaffle in forum Samsung Galaxy S8 & S8+
    Last Post: 09-18-2018, 07:45 AM
  2. Nilkin thin case
    By christianttt in forum LG V20 Cases & Accessories
    Last Post: 11-29-2017, 08:51 AM
  3. Note 8 camera uses same lens for both modes
    By Guru1uk in forum General Help and How To
    Last Post: 10-03-2017, 02:27 PM
  4. How I Made My Samsung OTG Adapter Work With My Case
    By srvctec in forum Samsung Galaxy Note 8 Cases & Accessories
    Last Post: 09-30-2017, 06:28 AM
  5. Replies: 0
    Last Post: 09-30-2017, 04:54 AM
