1. h2ofun's Avatar
    Okay, got my parts to try to see if I can display the N8 onto a monitor. But, so far no luck. So, I assume there is something you need to do to enable mirror out of the usb-c connection?
    10-03-2017 06:31 PM
  2. Stealthieone's Avatar
    Dex station?
    10-03-2017 08:30 PM
  3. Stealthieone's Avatar
    Is the monitor connected to a pc
    10-03-2017 08:32 PM
  4. h2ofun's Avatar
    After playing with various monitors, this is what I found works. HDMI input, check. VGA input check. Key is this monitor could accept higher resolutions. Another older monitor connects, but say out of input so it cannot accept the resolution output of the N8, even though I have it as low as it goes. Now, if I could get it lower without rooting.
    10-03-2017 08:44 PM
  5. dpham00's Avatar
    Dex works even on my old ancient monitor which isn't even fHD
    10-03-2017 10:43 PM
  1. Gear S2 ~ Big black dot on screen..?
    By loreburne in forum Samsung Gear S2
    Last Post: 10-04-2017, 09:57 PM
  2. Replies: 1
    Last Post: 10-04-2017, 05:18 PM
  3. Problems with the V20 earpiece
    By talon1189 in forum LG V20
    Last Post: 10-03-2017, 07:30 PM
  4. how to sole g3 mobile signal issue and frp
    Last Post: 10-03-2017, 06:50 PM
  5. Why Note8 personalization settings reset to default after reboot?
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 10-03-2017, 06:13 PM
