10-24-2017 01:04 PM
30 12
tools
  1. NotAnAppleGuy's Avatar
    I have gone from having pretty much a day and a half of battery to a 11 hour battery.
    Anyone else experiencing a sudden change?
    10-17-2017 05:34 PM
  2. NotAnAppleGuy's Avatar
    Number 2
    10-17-2017 05:34 PM
  3. Mike328's Avatar
    yes when I first got it I remember my battery life beaing really good when the phone was calculating my usage now it's really just average at best I have a battery pack tho so I don't mind but it could be better
    Milton D likes this.
    10-17-2017 06:13 PM
  4. Milton D's Avatar
    Yeah it feels like my phone has turned into my s7 edge which a knackered battery.
    Did Samsung program it to last longer at first then after a month of use go bad?
    10-17-2017 06:20 PM
  5. Milton D's Avatar
    10-17-2017 06:20 PM
  6. Disk4mat's Avatar
    So far my battery life is the same. But Ive been very disciplined about installing apps. Before something goes on my N8 I install it on my old N4 to A) see if I want or need the app and B) to see how much resources it uses , ram, battery etc.
    In general Ive found any social media app or browser + wifi = faster battery drain. Not as much when using network data. I get about 3 days on a full charge.
    jimd1050 likes this.
    10-17-2017 06:41 PM
  7. sistasweetpea's Avatar
    I've noticed it, my battery life has never been as good as yours, but it was good for me and now it's noticeably worse. I was getting a full day with 6-7 hours sot, and the last two days for sure I've only gotten 3-4 hours sot having to charge by 6pm. I installed a few random apps some days ago and I uninstalled them to see if that helps.
    10-17-2017 06:57 PM
  8. supreme8124's Avatar
    Mine battery life has changed for the worse also.
    10-17-2017 07:30 PM
  9. chyeo1979's Avatar
    Felt mine got worse too
    10-17-2017 07:37 PM
  10. philliplavelle's Avatar
    This seems a little worrying. Mine is due to arrive tomorrow, but the fact that this is apparently hitting multiple users is concerning!
    10-17-2017 07:40 PM
  11. stuckingoo's Avatar
    Mine has gotten better. According to Gsam I'm running about 20 hours average with over 5 hours of screen time. Actually I can't believe I spend that much time with screen on but that's what the app says. I only install the apps I need and try not to install anything new but games.
    Jewels81 likes this.
    10-17-2017 10:29 PM
  12. NotAnAppleGuy's Avatar
    Lol omg it's been about a month now this.
    10-17-2017 11:16 PM
  13. Jewels81's Avatar
    Yelp Samsung fixed the batteries to get worse after a month. Yelp.......
    10-17-2017 11:33 PM
  14. Jewels81's Avatar
    I've had mine for 6 weeks now and it's about the same as when I got it. Some days great, some days could be better. All depends on how I use it. Some days I use it more than others. Hell of a lot better than my note 5 and that battery didn't start dropping til about 3 or 4 months or so before I got the note8 and I've had the note 5 since it came out.
    10-17-2017 11:37 PM
  15. j_hansen's Avatar
    I see a bit more power drain but I'm away in spain roaming and have hotspot on a lot to allow my mate use my mobile data lte/4g so I guess that accounts for a good bit, still 5 hour sot so not worried
    Jewels81 and Ca_lvn like this.
    10-18-2017 03:12 AM
  16. kirksucks's Avatar
    Isn't this normal though? He more crap you throw at it along with age it's going to take a hit over time.
    jimd1050 and Disk4mat like this.
    10-18-2017 10:12 AM
  17. srvctec's Avatar
    No difference on mine after a month as of today. If anything, it seems better now.
    Jewels81 and jimd1050 like this.
    10-18-2017 10:14 AM
  18. srgonu's Avatar
    My Note 8 is pretty consistent. It's been a month now.
    10-18-2017 10:59 AM
  19. evohicks's Avatar
    I don't know if it's in my head but I actually think my battery life is better, I can regularly come home from work with 90%+ battery life and go to bed with over 75%
    I'm obviously not a heavy user but I find the battery great.
    10-18-2017 11:06 AM
  20. pault8084's Avatar
    mine has improved and now going two days on a charge.
    10-18-2017 12:25 PM
  21. xplod566's Avatar
    Ok so this happens because of Google location sharing .Google keeps on sharing your location every minute to check where u go,so that they can give u suggestions about nearby places etc etc.
    To disable just go to Location and disable location sharing.you will still be able to use GPS flawlessly ,it's just that everyone it won't be sharing your location deatils.
    This is common for all phones.i hope Google fixes this ****ty thing.realy annoying to see such things
    10-18-2017 12:48 PM
  22. frankenhooker's Avatar
    Mine seems better, probably because the initial novelty has wore off and I’m not constantly playing with it. I get around 30 hours with about 4 hours on screen. I came from an S6 edge so the battery life on the Note 8 is a revelation.
    10-18-2017 12:51 PM
  23. o4liberty's Avatar
    No change here battery goes 12 to 15 hours of heavy use all day long. Email, photos, text etc still running strong.
    10-18-2017 02:43 PM
  24. kirksucks's Avatar
    All i see is under Location settings is Location Services:
    Google Location History (which is on)
    Google Location Sharing (which says I'm not sharing my location with anyone)
    10-18-2017 02:52 PM
  25. w7sg's Avatar
    You know what would help here is if you could go back & edit your post with the software version number
    10-18-2017 03:08 PM
30 12
  1. Replies: 1
    Last Post: 10-18-2017, 07:00 PM
  2. Could pixel 2 XL display color profile be changed?
    By quietlybrilliant in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 10-18-2017, 02:43 PM
  3. How can I remove the battery saveing mode
    Last Post: 10-17-2017, 05:03 PM
  4. Samsung s6 edge Changing Notification For one Contact changes all instead
    Last Post: 10-17-2017, 04:17 PM
  5. vivo y55l showing another battery icon
    Last Post: 10-17-2017, 03:30 PM
