Save big + get 3 months free! Sign up for ExpressVPN today
  1. ch5220's Avatar
    Anyone have an issue with the blue LED notification light staying on even though there are no notifications. It just started for the first time today, right after I used the wireless charger I got from the promotion for the first time. Even after I restarted my phone it still goes on every time I turn of my screen.
    10-20-2017 03:36 PM
  2. anon(3641385)'s Avatar
    That's interesting, I assign the blue led to telegram notifications, and it does what it should; and I also use the wireless charger.
    Okay, in settings there's some info:
    10-20-2017 03:58 PM
  3. ch5220's Avatar
    I don't have any unread notifications, and battery is fully charged, not sure what they're referring to with sound recordings. But since I fully restated my phone and it is still showing the blue night it can't be something that's just running in the background
    10-20-2017 04:09 PM
  4. anon(3641385)'s Avatar
    Another thought, are all notifications cleared from the notification bar:
    10-20-2017 04:22 PM
  5. rotorocker's Avatar
    I figured it out, its under Hide when screen is off. if you search for the term LED Indicator you'll get it in the settings. So you want to enable Hide when screen is off from the hide visual notifications section.
    anon(3641385) likes this.
    10-31-2017 04:49 PM
  6. Jacob Ekker's Avatar
    This is not a solution...
    You're turning the notification light off manually without addressing the cause.
    This is like "I can turn the volume of my phone off by powering it down; problem solved"
    04-13-2018 12:00 PM
  7. v0mitr0n's Avatar
    Is your Power saving Mode on? I was having the same issue, turned off Power saving, and now the blue LED doesn't remain on. I toggled Power saving back on, and the blue LED still remains off.
    Kinda strange and random.
    06-24-2018 09:09 AM
  8. Streamdreamer's Avatar
    People don't get it. I am having same issue. Blue light stay on steady, does not flash and there are NO new notifications. It's just on and wasting battery and is very frustrating. If you turn the LED off, then NO new notifications will be known. Do we understand now? The answer, most likely, is this phone is a piece of junk. Just got the S8. I'll go into store. How much you wanna bet they d=say "factory reset" to fix issue. I'll bet you money. ALSO, when phone is changing, red light is REPLACED by blue light. WTF?
    10-26-2018 10:47 AM
  9. Dooki's Avatar
    have you tried clearing both caches, starting on safe mode, going through your advanced notification settings and trying to toggle individual apps?
    10-29-2018 11:26 AM
  1. Turn off Sunlight Mode
    By BriniaSona in forum Samsung Galaxy Note 8
    Last Post: 10-21-2017, 09:02 AM
  2. Large texts with view all won’t open
    Last Post: 10-20-2017, 05:47 PM
  3. My gear s3 won't connect via app
    By Android Central Question in forum Samsung Gear S3
    Last Post: 10-20-2017, 03:30 PM
  4. WIFI doesn't turn on after installing a viper custom rom in HTC one M8 verizon
    By Android Central Question in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 10-20-2017, 12:55 PM
  5. How to silence System sounds at device ON, OFF, and other system events
    Last Post: 10-20-2017, 11:33 AM
