1. sinic999's Avatar
    Is it possible to set the note 8 to automatically set to battery saving mode on a schedule like the do not disturb mode?
    10-25-2017 11:41 AM
  2. j_hansen's Avatar
    Guess you could set up a bixby command to do it so you just say high power or low power and it adjust everything you set that command to do
    10-25-2017 11:47 AM
  1. Can you restrict WiFi access on Android to specific SSID's/Connections?
    Last Post: 10-29-2017, 03:55 PM
  2. Obb data being read for only one game on ext SD card?
    By Dennis Roman1 in forum General Help and How To
    Last Post: 10-26-2017, 03:26 AM
  3. Why is my phone not getting switched on?
    Last Post: 10-25-2017, 12:55 PM
  4. skype video on H96 pro plus ( 3/32 ) android 7.1.1 nougat
    Last Post: 10-25-2017, 11:27 AM
