Protect your tech:Get an Upsie warranty & save up to 70%
  1. notchendavid's Avatar
    On certain apps my screen turns everything white and compresses all the information to the middle of the screen. When closing and opening once again, sometimes it goes back to normal. On certain apps where I cant close and open, i'm left with a white screen and no way to fix the problem. Has this happened to anyone? Does this seem like a problem with my phone or is there a way to fix it?
    Attached Thumbnails White screen. Compressed contents on Note 8 Problem-23191854_10212588977512020_378843708_o.jpg
    11-02-2017 04:55 PM
  2. Laura Knotek's Avatar
    What app are you using?
    11-02-2017 05:04 PM
  3. notchendavid's Avatar
    This is the common Gmail app found on all Note 8's. It also occurs on playstore windows as well as other external apps.
    11-02-2017 06:07 PM
  1. note 8 screen burn in
    By Kingbelial in forum Samsung Galaxy Note 8
    Last Post: 03-17-2019, 12:07 PM
  2. how do you put minutes on a i RULU phone to use it like a regular smartphone
    Last Post: 11-02-2017, 06:49 PM
  3. Why is my rca tablet is stuck on no command
    Last Post: 11-02-2017, 06:47 PM
  4. Replies: 3
    Last Post: 11-02-2017, 05:05 PM
  5. Screen size for generic screen protector
    Last Post: 11-02-2017, 03:50 PM
