1. Fofuffafol's Avatar
    Hey everybody, this is my first post here! I'm not very good with english so don't be mean with me :c
    I bought my Note 8 almost a month ago and i noticed that my battery didn't last as much as the same of any other that i read online.
    I can reach almost 5 hours of SOT but only if i put some video (Netflix or Youtube) but usually it drain really really fast and i do something like 2-3 hours.
    Please i'm going crazy here.
    Attached Thumbnails Is my battery ok?-screenshot_20171119-213807.jpg   Is my battery ok?-screenshot_20171113-185508.jpg   Is my battery ok?-screenshot_20171113-185511.jpg
    11-22-2017 04:52 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! How's your cell signal during the day? Poor cell signal causes significant battery drain. Install an app like GSam Battery Monitor and see how the cell signal strength is throughout the day. If it's generally medium to low, or if it fluctuates a lot, that's probably a significant factor.
    11-23-2017 03:29 AM
  3. j_hansen's Avatar
    As above but also check if the likes of Facebook etc. is constantly turning on location service, I always found Facebook and its messenger app to be battery vampires
    B. Diddy likes this.
    11-23-2017 05:26 AM
  4. Fofuffafol's Avatar
    Thanks for your suggestions. When I am at work my signal is weak but at home is strong. I uninstalled the facebook app but i see no difference. I really dont understand! today it last 13 hrs but only 1.53 of SOT.
    11-23-2017 04:22 PM
  5. B. Diddy's Avatar
    Is the battery drain curve steeper when you're at work?
    11-23-2017 05:39 PM
  6. Fofuffafol's Avatar
    No, same drain! if i start to use it heavily i really don't know how fast it could drain!
    11-23-2017 05:54 PM
  7. B. Diddy's Avatar
    Facebook is a common cause of battery drain. WhatsApp might be as well. See what happens if you temporarily uninstall one or both of those apps.
    11-24-2017 12:24 AM
  8. Fofuffafol's Avatar
    Without facebook is same as before.
    11-24-2017 07:35 AM
  9. Baby_Doc's Avatar
    Try your phone in Safe Mode.
    If it still drains quickly, there it could be because of poor signal strength. It could also be a faulty battery, but if you are getting good SOT on some days,.that can't be. If in safe mode you get good battery life, you will need to find the app that is doing this. The most likely apps are those apps which you added that run all the time in the background, like security apps or bad battery saving apps. If I were to bet, it is probably poor signal reception, brightness set too high, Bluetooth on, or wifi scanning where you haven't connected.
    11-24-2017 07:58 AM
  10. Fofuffafol's Avatar
    Well, i don't have anything that run in background but WA. I have almost everything disable but i see a strong drain. Look what i've got last day!
    Is my battery ok?-screenshot_20171125-201202.jpg Is my battery ok?-screenshot_20171125-201205.jpg
    [the attched thumbnails are the old one.]
    Attached Thumbnails Is my battery ok?-screenshot_20171113-185508-1-.jpg   Is my battery ok?-screenshot_20171113-185511-1-.jpg
    11-27-2017 07:19 AM
  1. How to stop "Messenger is displaying over other apps" notification on Android 7.0
    Last Post: 12-05-2017, 05:14 AM
  2. Why my tablet charges slow and doesnt have sound anymore?
    Last Post: 11-23-2017, 03:32 AM
  3. where is the moto x clipboard located
    Last Post: 11-22-2017, 05:51 PM
  4. How do I unlock my Android phone without the password
    Last Post: 11-22-2017, 05:00 PM
  5. If i cancel my account with t-mobile, when can i open a new account
    Last Post: 11-22-2017, 04:00 PM
