1. klee0032's Avatar
    I remember on my S8+ when listening to music through Google music the controls for music like play/pause, forward and back would be in the notication shade when you're using your phone and swipe down. On my note 8 I can't be play a game and quickly swipe down and change a song. Is there a setting to turn this on?
    12-05-2017 10:17 PM
  2. B. Diddy's Avatar
    Is that only when you're playing a game, or any time? E.g., if you're on the homescreen while Google Play Music is playing, do you see the controls in the notification panel? If not, then go to the App Manager, select Google Play Music, and check the Notifications. Tap the Playback part, and make sure it's turned on.
    Zolti likes this.
    12-05-2017 11:49 PM
  3. aldo82's Avatar
    I get play music controls in the notification shade on mine
    12-06-2017 05:07 AM
  4. klee0032's Avatar
    Yeah the app notifications was off... Thanks for the help
    B. Diddy likes this.
    12-06-2017 10:58 PM
  5. Tanmay Agarwal's Avatar
    I did that
    But after I leave settings the playback controls aren't switched on
    If I go back to check the settings, it says they are off despite me switching them on
    12-07-2018 09:04 AM
  1. Music sound lowers whens Google Maps talking and is stuck at lower volume now.
    Last Post: 10-30-2018, 08:13 PM
  2. Why can't I disable conversation in gmail on my samsung s8 plus? I hate it.
    Last Post: 05-11-2018, 07:32 AM
  3. Pixel 2 Bluetooth Audio Quality With Music Playback.
    By KrisYYC in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 01-09-2018, 06:14 AM
  4. My phone keeps pausing when i listen to music
    Last Post: 12-06-2017, 12:11 AM
  5. will the elephone s8 work in canada
    Last Post: 12-05-2017, 04:34 PM
