    I want to take a night sky photo with my Galaxy note 8, but its iso is only 800. But I can see it's auto iso can increase your 1600.
    12-10-2017 12:26 AM
  2. ManiacJoe's Avatar
    Are you saying that the scale goes only to 800 or that you cannot set it to a higher value when in manual mode?
    12-10-2017 01:28 AM
  3. Boremey's Avatar
    yes. I want to need higher iso than 800 in manual mode
    12-10-2017 06:11 AM
  4. ManiacJoe's Avatar
    A quick internet search suggests that the Note 8 has a max ISO of 800 when in manual mode.
    I am not sure if installing a different camera app will help or not.
    Let's see if we get some better eyes seeing this thread if it is moved into the Note 8 forum...
    12-11-2017 05:57 AM
  5. Javier P's Avatar
    Mod note. Thread moved to the Note 8 forum for better visibility.
    12-11-2017 06:21 AM
  6. Deke218's Avatar
    Camera Zoom FX installed on my Note 8 goes of to 3200.
    12-11-2017 08:33 AM
  7. toenail_flicker's Avatar
    Camera FV-5 offers 6400.
    12-11-2017 09:23 AM
  8. Spencurious's Avatar
    Although apps other than the Samsung one can simulate a higher ISO, you'll lose so much detail the stars may not show clearly. Better to use a lower ISO and a longer exposure. Make sure the phone is steady, use the manual (pro) settings and select the exposure manually - it can go up to 10 seconds.
    12-11-2017 10:10 AM
  9. Boremey's Avatar
    I have installed camera FV-5 but iso only set to 800
    Spencurious likes this.
    12-12-2017 01:05 AM
  10. andytiedye's Avatar
    Open Camera can set the ISO up to 7237 (no idea why that number)
    12-14-2017 09:31 PM
  11. Nakrohtap's Avatar
    Agreed. Higher ISO will not give you the picture quality you are looking for. You will also need to invest in a tripod, if you don't have one already.
    12-15-2017 06:14 AM
  12. Fr0gburp3r's Avatar
    The higher the ISO, the more noise. I try to stay away from high ISO unless I’m in bright daylight taking action shots.
    12-19-2017 09:49 AM
  1. How do i turn off my galaxy tab a without any buttons?
    Last Post: 12-12-2017, 03:35 PM
  2. Why does my screen show a static screen when I try to switch my S3 phone on?
    Last Post: 12-10-2017, 07:03 PM
  3. Unable to move to SD card not enough
    Last Post: 12-09-2017, 10:25 PM
  4. Why isnt my videos playing from beginning to end
    Last Post: 12-09-2017, 10:21 PM
  5. thoughts about the upgrade from Note 4 note S8+
    By datum9 in forum Samsung Galaxy Note 4
    Last Post: 12-09-2017, 09:26 PM
