1. PaulQ's Avatar
    The Note 8 (and S8 I assume) has a really crappy looking incoming call "wallpaper." It's like a white/green/red/mush/light blah. I know the little contact photo is there. From an aesthetics point of view, can it be changed??
    Thanks!
    12-10-2017 11:36 PM
  2. Tim1954's Avatar
    It's fairly ugly alright! Many of us have been clamouring for dark themes for years now, but Google keeps producing those revolting, blinding themes...
    With each new version we get teased with dark themes to find nothing of the sort on release! Tragic...
    12-11-2017 03:29 AM
  3. Heavens1's Avatar
    Thanks!
    I bought this theme for a couple of bucks:
    https://forums.androidcentral.com/e?...token=Gn1LF9PD
    I appreciate it's a theme that includes the phone screen, as opposed to just a phone theme, but I thought I'd let you make your mind up.
    Attached Thumbnails Is there a way to change the incoming call background away from those washed out colors?-screenshot_20171211-194948.jpg
    12-11-2017 03:53 AM
  4. 103Softail's Avatar
    This one's just called "red"
    12-11-2017 06:42 AM
  5. Nakrohtap's Avatar
    I think the OP is referring to the background when receiving an incoming call. I just didn't want to see this thread turn into a dialer theme thread. If this was as easy as changing a theme, it wouldn't be an issue. The Samsung Call app is the one controlling the calls and AFAIK can't be themed.
    12-11-2017 07:20 AM
  6. PaulQ's Avatar
    Exactly. Not the dialer.
    I guess I have to live with it.
    12-11-2017 11:03 AM
  7. 103Softail's Avatar
    Oh, ok. I don't notice the background during call......it's usually against my ear! What about substratum & Swift Black?
    12-11-2017 03:07 PM
  8. PaulQ's Avatar
    LOL... Wait, you keep your phone against your ear all the time?
    I am referring to what you see when the phone is ringing. For example, it starts ringing and you look down at it... that.
    12-11-2017 04:14 PM
  9. mysamsungs7e's Avatar
    https://forums.androidcentral.com/e?...token=AEdEmXmO
    I love his work!
    Heavens1 likes this.
    12-11-2017 04:22 PM
  10. PaulQ's Avatar
    https://forums.androidcentral.com/e?...token=lOptWaph
    Just as an aside... what is this app called? Your link doesn't work from a desktop computer. Thanks!
    12-11-2017 06:34 PM
  11. Heavens1's Avatar
    It's a samsung theme that I get to by : settings, wallpapers and themes
    Attached Thumbnails Is there a way to change the incoming call background away from those washed out colors?-screenshot_20171212-103702.jpg
    12-11-2017 06:38 PM
  12. srvctec's Avatar
    There is a Samsung dialer app update as of a few days ago. I won't download it as mine is working fine and since Samsung chooses NOT to be transparent about EXACTLY what the update includes, not updating until I find out from many others it doesn't break something. If you want to update and let us know if it works, and what changed, that would be cool. Maybe they changed it to include background options?
    To update, go to you Galaxy Apps app and it should show up as needing updated.
    12-11-2017 06:48 PM
  13. Heavens1's Avatar
    I updated, and have used the phone numerous times since without issue, but, I can't identify what they updated, lol.
    Also, I can't find the samsung apps, like phone, in the galaxy store once they're updated. Where are they located?
    12-11-2017 07:49 PM
  14. srvctec's Avatar
    Once in the Galaxy Apps app, tap on the 3 dots in the upper right. Then tap on My Apps followed by All. You should see them all listed there.
    12-11-2017 09:41 PM
  15. Heavens1's Avatar
    No unfortunately dialer, and most other basic samsung type apps don't show there or anywhere else, until an update comes.
    12-12-2017 02:01 AM
  16. Ten8yp's Avatar
    For all the abilities that Android (and my Note 9) has, one would think this simple thing would be EASY to change. But they pretty much lock you into whatever theme you have running. If you change the wallpaper, lock screen, or ANYTHING about the themes it reverts right back to the **** colored in-call color background. Disappointing to say the least.
    12-02-2018 03:49 PM
  1. How to disable the blue pop-up "call reminder" screen after every call
    Last Post: 02-07-2018, 07:12 AM
  2. Tried Nova launcher and went back to stock
    By mysamsungs7e in forum Samsung Galaxy Note 8
    Last Post: 12-25-2017, 12:30 PM
  3. How do I get voicemail icon short to my phone
    Last Post: 12-11-2017, 05:38 AM
  4. Can straight talk be switched to metro pcs I want to switch.
    Last Post: 12-10-2017, 10:11 PM
  5. why does the map disappear when I answer a call on Bluetooth?
    Last Post: 12-10-2017, 10:05 PM
