Do you turn those off?
Turn off the Window & Transition animation scales but change Animator duration scale at 0.5 because the latter is required to stay on for some phone animations
Currently, the only issue turning them all off causes (providing you are using the latest Touchwiz) is that when in the Samsung email app, which I use for work, the details section is invisible. To prevent that, one must turn o Animator duration to .5x. I tried contacting Samsung about this but their web form failed, using their browser on a Samsung phone, which makes perfect sense.I turn them all off on every phone. Never had any issues.
Same, I haven't had the need to turn them off with this phoneI just leave them alone as set up out the box. The note runs great with the animations
Sloooooow motion.It's quite interesting to switch the Animator duration scale to 10x and then go back and do a few things with phone. Try it
That's a great discovery. I've been wondering why the details don't show up, I use Samsung email too. Going to change it now, thank youCurrently, the only issue turning them all off causes (providing you are using the latest Touchwiz) is that when in the Samsung email app, which I use for work, the details section is invisible. To prevent that, one must turn o Animator duration to .5x. I tried contacting Samsung about this but their web form failed, using their browser on a Samsung phone, which makes perfect sense.
See attached screenshots for what happens if you turn all animations off or not.
I wish they would fix this issue so I can turn them all off!
//uploads.tapatalk-cdn.com/20171211/36ae3a34a9922940ec8b2c7373aad743.jpg//uploads.tapatalk-cdn.com/20171211/d45bfcff6a4f40204269416e16fbc140.jpg//uploads.tapatalk-cdn.com/20171211/ab7eb0c14d8e42bc1dd110118c256b32.jpg
