1. aldo82's Avatar
    Any ideas what to do to improve this? My battery isn't the best and android system has over 4 hours cpu time and is second on the list. Any way to make this use less?
    12-23-2017 06:20 PM
  2. Stealthieone's Avatar
    Put all apps you dont need notifications from to sleep and disable unnecessary bloatware
    12-24-2017 12:02 AM
  3. Tim1954's Avatar
    Yup, block background processes..
    You can calm them down nicely.
    12-24-2017 01:12 AM
  4. aldo82's Avatar
    Do you use a. App to disable bloatware and if so which one?
    12-24-2017 03:08 AM
  5. z0ove's Avatar
    BK Disabler and stock app battery optimization to keep enable but sleeping somw apps while I'm not using them
    12-24-2017 03:27 AM
  1. Replies: 3
    Last Post: 03-25-2018, 08:26 PM
  2. Android ES File Explorer - Switch Back to Music Player
    Last Post: 12-23-2017, 06:05 PM
  3. I am not getting a home screen to be able to set up my mxq pro
    Last Post: 12-23-2017, 05:57 PM
