Originally Posted by
naturalguy In all my years of owning smartphones, I've never had my battery go down to zero. If you are monitoring your battery percentage it should never happen.
I've had phones go down to, "zero" plenty of times with no problems. The thing is, zero does not mean the battery is completely dead; especially with LiIon/LiPoly batteries. It means that the battery is at a certain level and if it were to discharge more, the battery could be severely damaged when you try to recharge it. Read the info in the link I posted.
