1. Mama2Many's Avatar
    I have car chargers in all my cars for my LGV10 that I had. Now I have the Note 8 and it has a different input than my LG. Can I just buy a new cord that fits my USB charger to my Note or do I have to buy an entire new charger?
    Thanks!
    01-09-2018 10:39 AM
  2. amyf27's Avatar
    You can buy a USB C adapter to make the cord work with your Note 8. That is, if the V10 use a micro USB cord to begin with? The part that connects to the charger itself is always going to be the same no matter what phone you have but of course the other end of the cord you may need adapter depending on the phone type
    Mama2Many likes this.
    01-09-2018 10:51 AM
  3. SpookDroid's Avatar
    Yup, you can. Either get the USB-C cable (or use the one that comes with your phone) or get a micro-USB-to-USB-C adapter (which, also, comes in the box). Problem with the adapter is that some chargers will not recognize fast charging due to the added impedance, so that might be an issue if you have a fast-charger for your car. Also, if you do, make sure that the Fast Charging is compatible with your Note 8 or it will only charge with 'normal' speed.
    01-09-2018 11:01 AM
  4. amyf27's Avatar
    If your V10 has a USB C cord then it will work on your Note 8. I had a v20 a while back and regularly used that cord to charge my Note 8
    01-09-2018 11:04 AM
  5. SpookDroid's Avatar
    V10 is microUSB OP will need either a new cable or an adapter.
    01-09-2018 11:34 AM
  6. amyf27's Avatar
    Those adapters are very handy☺
    01-09-2018 11:34 AM
  7. mike104393's Avatar
    Or buy yourself a fast wireless car charger mount
    01-09-2018 11:55 AM
  8. Mama2Many's Avatar
    Thanks for all the replies!!!! I will try the adaptor ....forgot it was in the box! I want to get a wireless car charger but until then....
    speaking of...what's the best wireless car charger out there? I've been looking around online.
    01-09-2018 12:13 PM
  9. SpookDroid's Avatar
    Just beware of wireless chargers without a cradle to sit on. The note is heavy and will fall off those sticky ones and even slide on most magnetic ones come the first bump in the road.
    jimd1050, Mama2Many and j_hansen like this.
    01-09-2018 01:44 PM
  10. jimd1050's Avatar
    ...that's better!
    Mama2Many and SpookDroid like this.
    01-09-2018 02:44 PM
  11. Mama2Many's Avatar
    https://www.amazon.com/Fast-Wireless...cUvbUpU6131592
    I'm considering this one because it can mount 2 ways. Any experience?
    jimd1050 likes this.
    01-09-2018 03:40 PM
  12. SpookDroid's Avatar
    Don't have experience with those but it does have a grip on it, so it's OK. It's the ones with a sticky, angled surface or magnetic plates that aren't suited for something this big. That one should be fine unless the build is crappy and the grip arms open up on their own.
    jimd1050 and Mama2Many like this.
    01-09-2018 03:47 PM
  13. Mama2Many's Avatar
    I drive a Jeep and an E350 Super Duty. Trust me....I will not trust my phone to a sticky pad. LOLOL
    jimd1050 and amyf27 like this.
    01-09-2018 04:16 PM
  14. jimd1050's Avatar
    Agreed, I have an F350 Super Duty and it's stiff so I know what you mean!
    01-09-2018 10:46 PM
  15. Chromium 4's Avatar
    I got a dual port Aukey 3.0 quick charger with the braided cable. It works for both my LG V20 and Note 8.
    Mama2Many and Super Dave426 like this.
    01-09-2018 11:02 PM
  16. TabGuy's Avatar
    Exactly. I've had a wireless charger in my car for years. I never touch a cord so it doesn't matter what kind of wire is going to the phone holder.
    01-10-2018 10:44 AM
  17. anon(7901790)'s Avatar
    I have the iOttie Easy One Touch 4 Wireless. It's Fast Charge compatible and charges my Note 8 with no worries.
    I found it at Best Buy, and I've seen it at Walmart.
    https://forums.androidcentral.com/e?...token=P_OzBBfI
    Super Dave426 likes this.
    01-15-2018 12:49 AM
  18. Mama2Many's Avatar
    I bought a Ptuna wireless car charger. it had good reviews but it won't charge my phone with a case on. Anyone have one that works with a case on your phone?
    01-15-2018 09:22 AM
  19. LuvULongTime's Avatar
    I have one of these as well but haven't used it with my note yet. Does it quick charge the phone?
    01-15-2018 10:43 AM
  20. Brew Swayne's Avatar
    OP, as others have mentioned, micro usb to micro usb c adapters are the way to go. You should have recieved 1 with your phone.
    I bought these when I got my Note 8 and they're great. Saved me from needing to buy micro usb c cables. And the tether chain is also great. Don't have to worry about losing the adapter in the event that I need the old micro usb plug instead. Can't beat it for $6.
    https://www.amazon.com/dp/B072X5RGDM...cUvbUpU6137080Car charger question-smartselectimage_2018-01-15-15-24-40.jpg
    01-15-2018 02:25 PM
  21. anon(7901790)'s Avatar
    The one by iOttie that I mentioned works with a case.
    01-15-2018 07:09 PM
  22. donm527's Avatar
    I bought the flush mounted Aukey charger and braided cables. I don't fast charge my phone so didn't care for the 3.0. The braided cables are better than stock IMO.
    https://www.amazon.com/gp/product/B0...cUvbUpU6137358
    anon(7901790) likes this.
    01-15-2018 08:14 PM
  1. Android. Bluetooth and your Car?
    By ThrowinRocks in forum Samsung Galaxy S8 & S8+
    Last Post: 01-12-2018, 03:06 PM
  2. Increase screen timeout when connected to car
    By stevehesby in forum Android Auto
    Last Post: 01-09-2018, 12:25 PM
  3. Pixel 2 XL Verizon Variant (G011C?) Questions
    By GSDer in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 01-07-2018, 10:30 PM
  4. On screen button question pixel 2
    By captnpenguin in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 01-07-2018, 07:39 PM
  5. I have questions...
    By mrtonk in forum Android Wear / Wear OS
    Last Post: 01-07-2018, 12:30 AM
