1. Victory Pete's Avatar
    It seems my Galaxy Note 8 Fingerprint Scan is draining the battery. I have had it for a month and get exactly one day before a charge. This morning I added Fingerprint and at exactly 12 hours the battery is 5%.
    01-17-2018 04:37 PM
  2. SpookDroid's Avatar
    Do you touch it a lot? The FPS isn't active unless something conductive is touching it. I never noticed any difference in battery life with or without (long story, but had to live without FPS for a couple days).
    rdubmu likes this.
    01-17-2018 05:14 PM
  3. Victory Pete's Avatar
    Yes, I guess I access it a lot. It is such a drastic change though, I cant really charge it mid day.
    01-17-2018 05:20 PM
  4. cwbcpa's Avatar
    Have you looked at your battery usage in the settings menu to see what is actually using your battery? It's highly unlikely that it's the fingerprint scanner draining your battery.
    SpookDroid and SR45 like this.
    01-17-2018 05:23 PM
  5. Victory Pete's Avatar
    Nothing else has changed and I get half as much battery life.
    01-17-2018 05:30 PM
  6. SpookDroid's Avatar
    If you turn it back off, does your battery go back to normal?
    rdubmu likes this.
    01-17-2018 06:31 PM
  7. bassplayrguy's Avatar
    I think there has to be something else. I use my FPS and I easily get a day and 6 plus hours of screen time.
    rdubmu likes this.
    01-17-2018 07:07 PM
  8. cwbcpa's Avatar
    Did you check to see what is actually using your battery life?
    01-17-2018 07:40 PM
  9. Victory Pete's Avatar
    My Norton Security was at the top of the list with 1.8% usage. So I clicked it and it dissapeared. Not sure what that did.
    01-17-2018 07:58 PM
  10. donm527's Avatar
    I use Bitdefender. Doesn't come up on my usage radar at all. Something wrong there with yours showing at top of list.
    01-18-2018 05:57 AM
  11. Victory Pete's Avatar
    What is wrong?
    01-18-2018 06:03 AM
  12. Climb14er's Avatar
    What is wrong?
    Stop using it and go to another method for security like a four digit pin. That's what I did and I have no battery drain.
    01-18-2018 07:05 AM
  13. cwbcpa's Avatar
    I would expect that Android System would be at the top of the list if the fingerprint scanner was causing the problem.
    I have never used antivirus software on any phone so I don't know what impact they should or should not have. If that is the issue, my first step would be to really consider why you think you need that software on your phone.
    01-18-2018 02:18 PM
  14. SpookDroid's Avatar
    That. If the FPS was the problem, the OS would show up top (not the only reason why it would, but if that were the culprit, that would be a good place to start looking). Also, turning your screen on and typing a password takes way more energy out of your battery than swiping your finger on the FPS. If your usage remains the same, you shouldn't be seeing a battery drop from using FPS.
    cwbcpa likes this.
    01-18-2018 04:33 PM
  15. Victory Pete's Avatar
    Well since I clicked on the Norton that was on the top of list, the battery is back to normal. Why the Fingerprint affected the Norton that day is a mystery. Thanks for all the help.
    01-21-2018 09:20 AM
  16. rdubmu's Avatar
    It wasn't the fingerprint reader. You are connecting two dots that are not connected.
    01-21-2018 11:48 AM
  17. Victory Pete's Avatar
    Here are 2 dots:
    I added Thumbprint Reader.
    My battery life was cut in half immediately.
    I connect them until proven otherwise. Apparently the Norton had something to do with it also, so there is another dot.
    01-21-2018 12:15 PM
  18. cwbcpa's Avatar
    Here are 2 dots:
    Lol. I understand how you’re thinking. I handle problems the same way.
    Based on the factors that you have presented, I can tell you with a relatively high level of certainty that the issue is not the fingerprint scanner. I can’t firmly tell you it’s Norton, but that would be my lead suspect at this point. I would definitely consider why you think you need that app. I hope you get it worked out.
    01-21-2018 12:42 PM
  19. Victory Pete's Avatar
    I love Norton, I have it on all my devices. Since I clicked on it in the Battery Usage section, it is back to normal and hasn't showed back up as a High Usage item. Before I added Fingerprint, this never happened in the month I have had the phone. Connect the dots, why not?
    01-21-2018 12:50 PM
  20. cwbcpa's Avatar
    Hopefully it settles down for you and it’s smooth from now on.
    01-21-2018 01:00 PM
  21. Victory Pete's Avatar
    Yes thanks, I am new to this phone and have a lot to learn.
    cwbcpa likes this.
    01-21-2018 02:14 PM
  22. SpookDroid's Avatar
    Glad it's back to normal and you can still use the FPS
    01-21-2018 08:06 PM
  23. Victory Pete's Avatar
    Thanks!
    01-21-2018 08:13 PM
  24. cwbcpa's Avatar
    I've had every Note since the Note 2 and I still learn new things all the time. It just does so much. If you don't take the time to learn, you are really doing yourself a disservice. Enjoy!
    01-21-2018 08:34 PM
  1. No note love....
    By mike104393 in forum Samsung Galaxy Note 8
    Last Post: 01-20-2018, 09:41 PM
  2. Samsung Olympic inspired Note 8
    By Gray Area in forum Samsung Galaxy Note 8
    Last Post: 01-19-2018, 07:22 AM
  3. phone won't charge, it freezes, its a galaxy s6
    Last Post: 01-17-2018, 03:18 PM
