Originally Posted by
CraesheTurbo Hey guys, have a note 8, so I was wanting some advice. I leave GPS on all day long, need it for work.
I want an app that will auto turn off/on WiFi when I leave or enter selected GPS coordinates essentially.
When I leave my home WiFi network, I use the phone internet until I get back home, but want an to turn the wifi antenna off and on when I get there.
Any suggestions?
Lots of apps in the play store, was seeing if y'all had direct advice.
Install and use IFTTT (If This Then That). Create two objects - one that is called when you enter an area, and one called when you leave that area. First pick IF, and that would be LOCATION, then "When I enter an area", then pick THAT, which you would select as "Android" and then "Turn WiFi On" (or Off if you selected "When I leave an area."). Let me know what you think... I use it for turning on and off WiFi when arriving or leaving areas that have it, for turning my phone volume down and vibrate on when I get to work, then turning the volume back up when I leave work, etc.
