Smart lock doesn't work.
Dooki
1,015
3
38
does no smart lock work? Bluetooth, ect.
when I set up location scared lock I set it at all four corners of the house, never have issues.
I also have a word issue with trust agents. when I restart my phone I have to turn Google trust agents off, restart, then turn them back on. make sure your trust agents for Google is on, if they are, turn them off, restart, then turn back on.
kirksucks
2,089
27
I douse blue tooth that often. When I go to set the location again, the coordinates I'm at are already saved.. Multiple times.
tatootie67
191
How do you set up the bluetooth connection smart lock? Please explain, is it a settings option? Thanks for the help.
It's under settings, lock screen and security, smart Lock. Trusted devices. It will walk you through the process from there pretty much.
Ten Four
123
I agree, Stupid Lock almost never works reliably using the location feature. I have tried resetting the location using the map so it is based on lat/long and not on a street address, but it didn't really help. My guess is that it has a working radius that is less than the repeatability of GPS where I live. The fingerprint sensor is so fast and reliable though that the phone is unlocked by the time I can view it after picking it up.
anon(7901790)
2,403
I've found location Smart Lock inconsistent too. No issues with using the BT though.
I'm not sure how far from the recorded location it allows before it says you're not at work or home.
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,365
110
63
Smart lock by location was hit and miss for me. More a miss that I gave up on location. I wish Google would add wifi networks to smart lock.
brau0303
Trusted Member
Jan 21, 2015
511
I have mixed success with Smart Lock (based on location) it works for a while when I am at home but after several hours the device locks (almost like it forgets where it is) I have had awesome success with trusted devices (BT ear Buds mainly)
Cheers,
BR
Super Dave426
760
4
18
I must be in the minority because location Smartlock works for me. As long as I am home I don't have to unlock my phone. Even in the back yard. It says it's set by Google Maps.
